+12v R G B led strip to Arduino Nano.
Firstly hello.
Im having an school project right now where i have to use +12v R G B Led strip. I have all the components, Arduino nano, cables and so on. Will +12v R G B will work with arduino nano? And if it will then which pins i have to use to connect them to each other?
Thank you!
Is it an addressable strip or a strip with all the colours are the same?
If the latter you need here FETs to drive them.
If the former then yes but you only change them in groups of three.
Grumpy_Mike:
I've never seen addressable 12V LED strip. Could you point me to one?
The led looks like this. Im not sure if its adressable or not
It's a "regular" not addressable RGB strip as used in this tutorial -Usage | RGB LED Strips | Adafruit Learning System
