12v relay has coil resistance 70ohm want to wsitch using mega arduino
i have attached my circuit connection in attachment. i am tryong to use 12v relay with arduino. as per my knowledge it needs 70mA and arduino cant give more than 40mA. so i used a fet sl100. i have also used doide in4007 reverse. relay switches perfectly but when i check the voltage at the pin of micrcontroller it shows 1v instead of 5v. is it k?
can i go ahead or shud i do sumthing else??
instead of microcontroller signal if i givee 5v from microcontroller pin it works n styas 5v but if i try to give from digital pin it shows 1v only
but at same pin if try to run the blink program it works n shows me 5v n 0v.
if i remove connection from the board my pin shows 5v.
now my prog section which tells the pin to go high if my serial datastring 3 = 5 is:
if (inData[3] == '5' ) // TONE ATENUATOR SELECTION RELAYS
    digitalWrite(tonerelay[0], 1);
    digitalWrite(tonerelay[1], 0);
    digitalWrite(tonerelay[2], 0);
in my prog i am doing seriall comm:
my complete code if req is attaced.
full_prog_without_print_tone_special.ino (11.6 KB)
IS anybody there???
I'd have thought that the output pin of an arduino should be able to drive that transistor quite easily.
Have you included the line
pinMode(tonerelay[x],OUTPUT);
I used DDRD, DDRC PROG :
i declared port as o/p port:
DDRC = 0xff;// PORTC TONE INTENSITY PORT DECLARED OUTPUT PORT
