Im working on a solenoid project where I need to have the 12v solenoid valve controlling water flow of my showerhead. I would like to control the solenoid with a simple button.
I have been researching on how to operate a solenoid and found a couple of ideas:
I do have or could make a 9V-battery-powered source (but eventually id rather use a 120V AC source and somehow convert it to DC. For now Ill stick to the 9V x 2 battery pack idea. What would I need to power it from the wall socket? Im guessing one of those cables with transformers that will step down from 120V to 12V and a max of Amps that I would have to get from my valve manufacturer.
12V solenoid valve.
1k resistor, breadboard, jumpers.
TIP120 transistor - I need to get one - i only have a IRLB8721
A. Could that be used as a relay? Eventually I would have to buy a 12V relay, I understand.
B. Could those transistors and diodes work? eventually I would have to buy those mentioned above.
9V battery is a non-starter, not enough current for any kind of motor, servo or solenoid.
12V battery with decent current capability is where to start for a 12V solenoid valve. You'll
need enough capacity too to hold the valve open for the length of time needed.
(1) Power specification
A. Working Voltage:
AC: 24V/36V/110V/220V/380V
DC: 12V/24V/36V
B. Working temperature: -10℃~+50℃
Coil allows the temperature: 99℃
Do you have a part number/ manufacturer of the solenoid please.
The spec you have been given is the generic spec sheet for the type of solenoid valve, not your specific unit.
There's no link.
Click on the LINK toolbutton (just to the right of the computer monitor symbol, paste the link into the FIRST box that appears, click OK,
Type in a label for the link in the SECOND box that pops up, click OK, click POST. (SAVE)
Based on physical size of the coil, I would estimate the current to be anywhere from 200 ma to 500 mA but not more. Can you use a DMM to measure the current ? (do you KNOW how to do that ?)
You can use this mosfet which can be switched by an arduino output connected directly to the gate, as long as you add a suitable flyback diode (1n4004 to 1n4007)
Optionally, you can use this to switch a relay that switches the solenoid.
