12v variable to 5 volt scaling
I get how to take 12v and use a transistor to act as a 5 volt switch with iverted activation for on/off logic input but how do you take a 12 volt variable resistor type signal and convert it down to a 5 volt signal to use for analog in?
Have a pressure transducer and ultrasonic sensors that both work on 12 volt signal scales and would like to use with Arduino.
Thanks
Are you just looking for a basic voltage divider?
That will reduce a 12V signal to 5V, given appropriate resistor choices.
The QuadRAM shield: add 512 kilobytes of external RAM to your Arduino Mega/Mega2560
