12VSTEPPER MOTOR CONTROL WITH ANALOG--NEED HELP
Hello I am trying to control a stepper motor with a potentiometer, but eventually I would like to use a pulse sensor to move the motor.
I'm using this biploar stepper motor: http://www.adafruit.com/products/324
I've gotten it to work using this motor sheild: http://arduino.cc/it/Main/ArduinoMotorShieldR3
using code i found here: http://arduino.cc/forum/index.php?topic=89468.0
But I'm confused as to how to create code that will allow the potentiometer to control this motor.
(I'm new to arduino!!)
Any help would be awesome!! :astonished: :astonished: :astonished:
This is ironic. Someone named lownoise screaming at us.
So, you've noticed that a stepper motor steps. It does nothing else. How, exactly, do you want a potentiometer to "control" the stepper motor?
By control he means regulate the motor's speed and direction using the potentiometer.
I have the same question, some sample code would be greatly appreciated!
Thanks, -Slam
Let’s say you take 10K potentiometer. When you connect it(potentiometer) to arduino, it will show you the numbers from 0 to 1023.
Middle position of potentiometer should show you something about 510-512.
So(if i am not wrong) the code should look like:
val = analogRead(potentiometer_pin);
if(val >= 510K && val <= 512)
stepper.stop();
else if(val >= 513)
turn.right();
turn.left();
Well, that K looks out of place…
