14 line error aa raha hai
In file included from C:\Users\jagta\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\jagta\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:20,
from C:\Users\jagta\OneDrive\Documents\Arduino\JASS\JASS.ino:4:
C:\Users\jagta\OneDrive\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:39:6: error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
39 | #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
C:\Users\jagta\OneDrive\Documents\Arduino\JASS\JASS.ino:14:10: fatal error: camera_pins.h: No such file or directory
14 | #include "camera_pins.h"
compilation terminated.
exit status 1
Compilation error: camera_pins.h: No such file or directory
Welcome to the forum
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming Questions category of the forum
I'm not familiar with ESP32. But it will help others to help you if you post your sketch (don't forget to use code tags as described in How to get the best out of this forum) as well as the version of the ESP board package that you're using and the versions of libraries that you're using.
Which board are you compiling for?
Regarding the ESP32 board package, if you're using V3.x, downgrade to the latest 2.x using library manager. If you're using 2.x, upgrade to 3.x and see if that helps. Note that I'm talking about the ESP32 board package version, not the IDE version.
HI, @ig_jasss
Welcome to the forum.
Please post your code using code tags.
That error is referring to the fact that the camera_pins library cannot be found in the IDE.
You need to find the file and load it.
Where did you get the code?
Tom... :smiley: :+1: :coffee: :australia:
you need to fix that error first
➜ read tutorials on BLYNK so that you get the basics. Then you can do more.
