144 LED total 12 buttons with 12 options.
The arduino only has so many outputs on the board itself (a lot less than 144) is there anyway i can add a chip or something to control the rest of the leds?
http://www.pyrouniverse.com/forum/showthread.php?t=17929
basically the program monitors what button on the right is pressed and lights up the 12 firework options on the left when say button 1A is pressed A light shuts off etc etc... i have the program set up the way i think it should work the only problem is im not sure how to control all 144 LEDs any suggestions?
Hi Dustin,
http://www.mikrocontroller.net/articles/LED-Matrix
is a good example, you only need to extend this example to 144 LEDs.
good luck Mike
I hope you were talking about the schematics... its in German but thanks Ill give them a look over. How would I go about addressing each of them in the code then?
http://arduino.cc/en/Tutorial/ShftOut13
would something like this work?
Use Shift Registers or LED Driver chips. That way you can have as many LED's as you liek and only use 3 outputs from your Arduino.
you can also use some I2C IO chip like this one:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en023499
Another, similar, I2C chip. Remember you can drop multiple I2C chips on the same line, long as they have unique addresses :)
how would i know if they have a unique hex address? is all that stuff on the data sheet(s)? thanks guys now all i have to do is get the chips!
thanks again
yeah the address hex values are on the data sheet. thank you guys. now all i need are the chips and ill be set.... hopefully. :) :D
