15 Analog input 1 Arduino
Hello, I am trying to figure out how and what to connect to a single arduino uno's analog pins- I have 14 sensors which need to be connected to 1 arduino and read all at once or simultaneously but unfortunately it only has 6 analog pins. Any wiring/part/coding would be helpful.
Use a 4051 analogue multiplexer like the one in this project:- http://www.thebox.myzen.co.uk/Hardware/MIDI_Footsteps.html
or simultaneously
You can't do things simultaneously without extra hardware, it is seldom necessary anyway. The samples will be 0.1mS apart.
Can anyone tell me how to hook up the BOB-09056 to the arduino so i can read off 16 analog inputs. Thank you
On the SparkFun page about this interface under the documents tab there is this link which tells you. http://bildr.org/2011/02/cd74hc4067-arduino/
Can i connect to any other digital pins except 8,9,10,11 if i change it in the code?
Yes to any other pins to drive the address lines. The output still needs connecting to A0 or above.
Thank you very much.
