16*2 sparkfun lcd rgb
i have this datasheet for 16*2 sparkfun lcd rgb ,but i don’t know how to interface with m.c or arduino
ADM1602K-FS(RGB)-FBW.pdf (868 KB)
Start here
what is about pin 16, 17 and 18?
connect them to separate IO pins (via a 1k resistor) on the arduino. They control the Red, Green, and Blue content of the backlight.
can you give diagram of connection, because I burnt before, I don’t want to burn new one?
asaaaad:
can you give diagram of connection, because I burnt before, I don't want to burn new one?
Did you use the 1k resistors before?
Those pins simply connect to output pins on the arduino via a 1k resistor.
