16 Bit comparison
Hello!
Sorry for the Google translation, but my English is not that good to be able to describe my problem.
I am a strong beginner in arduino.
I would like to compare 16 bits, as quickly as possible in groups of 2 - 4 - 2 - 4 - 4, and find out in which group a change occurred.
Example:
new data - 10 0010 11 0000 1010
old data - 00 0010 11 0000 1010
here, bit 15 has changed from 1 to 0... I want to find this change simply and quickly and get the number of the changed bit, in this case 15.
I don't know how slow and system-intensive the "for - if" method would be on an Arduino 328.
Actually, this is all the processor would deal with, excluding 1 timer and 1 external interrupt.
Thank you all very much for your help!
I wish you a nice day!
The binary XOR operation give you a binary with only bits set, that different between new and old data:
uint16_t old_data = 0b0000101100001010;
uint16_t new_data = 0b1000101100001010;
uint16_t diff = old_data ^ new_data;
the diff will be 0b1000000000000000
Now you can easily test which bits are set
bool Diff1 = (diff & B1111) > 0;
diff = diff >> 4;
bool Diff2 = (diff & B1111) > 0;
diff = diff >> 4;
bool Diff3 = (diff & B11) > 0;
diff = diff >> 2;
bool Diff4 = (diff & B1111) > 0;
diff = diff >> 4;
bool Diff5 = (diff & B11) > 0;
Hello!
This is a very good solution, I tested it, it's fast, and it's not a "for - if" procedure consisting of 32 operation units.
I still have a lot to improve...
Because of object-oriented languages, many of us - like me - forget to learn the operations with BITs, even though everything started from there...from that became the ASM language and the rest.
I'm going back to the "school desk" - you have to learn these things! :slight_smile:
Thank you very much for your help!
