i want to transmit 16 bits from one arduino to another via IR transmitter i know how to transmit 8 bits but have no idea for 16 bits .
send it as two 8 bit bytes and then re assemble it at the receiving end
using a uint 16 and add the first byte in then bit shifting the second byte and or-ing it with the first byte into the 16 bit unint
Cheers Pete.
Arduino Reference
•lowByte()
•highByte()
Bainesbunch:
send it as two 8 bit bytes and then re assemble it at the receiving endusing a uint 16 and add the first byte in then bit shifting the second byte and or-ing it with the first byte into the 16 bit unint
Cheers Pete.
If you can provide me a sample code because i could find one
Waleed_Ahmed_Khan:
Bainesbunch:
Cheers Pete.
look what a simple Google search reveals
Hope this helps.
Cheers Pete.
