I am using an Arduino UNO as a master controller to set/read registers in the DRV8323 gate driver board. I have been troubleshooting this problem for a week now and decided to ask.
My issue is that I cannot read or set the registers. In the datasheet for the DRV board, it needs a 16-bit word (MSB is shifted in and out first) to be sent - the first but in position 15 is 1 for READ and 0 for write. I am using the Arduino SPI library and believe I have set everything accordingly, here is the code:
#include <SPI.h>
#define SELECT 10
pinMode(SELECT, OUTPUT);
pinMode(SELECT, HIGH);
// start the SPI library:
SPI.begin();
readRegister();
delay(100);
void readRegister() {
unsigned int response;
SPI.beginTransaction(SPISettings(125000, MSBFIRST, SPI_MODE1));
digitalWrite(SELECT, LOW);
// Read address 0x03
SPI.transfer16(0b1001100000000000);
response = SPI.transfer16(0x00);
//take the SS pin high to de-select the chip:
digitalWrite(SELECT, HIGH);
SPI.endTransaction();
// Display the data
Serial.println(response, BIN);
void writeRegister() {
// Set address 0x02 to 3x PWM mode
SPI.transfer16(0b0001000000100000);
When running the serial print displays 0s and then once in a while a seemingly ‘random’ binary number as follows:
0
0
0
0
0
0
0
1010000
0
0
0
0
0
0
0
0
0
My question is if I am properly sending the 16 bit words over SPI, and if not the proper way of doing it.
Thanks
