16 channel i2c Relay Board issue
I have 6 16 Channel realy boards. I use them with Arduino mega.
Some of works fine, some of not! My code is same.
for example
Wire.beginTransmission(0x20);
Wire.write(0x00); // IODIRA register
Wire.write(0xff);  // set entire PORT A as output
Wire.endTransmission();
if i use this code, all relay closes. if i write;
Wire.write(0b11111110);  // triggers first relay
with this code, you trigger relay 1 on port A. if u write 0b11111101 as address you trigger relay 2.
But in one relay board, some off address triggers another relay too. For example if i want to trigger first relay and write address as 0b11111110 it triggers second relay too. (another relay boards it don't happens)
You will probably say, "check wires", yeah i checked million times, all are true. My code is true, because it works well on other relay boards. And this board runs successfully 1 week ago. and now not!
What am i asking?
I use different function on this relay board several days ago. board i2c address is still same, port addresses are same, but i am affraid, relay address could be changed because of this code? Is there anyway to reverse default case?
have you check if for whatever reason on the board itself the relay input or output pins aren't soldered together? what type of load are you driving? is the relay well "protected"?
can you clarify which "16 Channel relay boards" you have?
