good day, i'm a beginner in arduino, but i used gizduino (arduino clone from e-gizmo company). my project is wireless robotic arm.. i use flex sensor to read the position of the finger. i also used APC220 for the transmission of data between two arduino. In order to control the multiple servo motors for my robotic arm, i used 16 channel servo driver (from e-gizmo company also). When i attached a single servo on servo driver, the servo motor work properly, but the problem is when i attach multiple servo on servo drivers, even a single servo didn't function. The basic setup maid by the said company is correct.
this is the sample code i've used:
e-Gizmo 16 Channel Servo Driver
Sample codes function for
16 Channel Servo driver.
Codes by:
e-Gizmo Mechatronix Central
http://www.e-gizmo.com
int x;
void setup(){
void loop (){
// for(x=0;x>=100;x++){
Serial.write(0x02);
Serial.print("0,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("1,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("2,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("3,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("4,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("5,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("6,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("7,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("8,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("9,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("10,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("11,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("12,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("13,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("14,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("15,500,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("0,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("1,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("2,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("3,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("4,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("5,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("6,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("7,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("8,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("9,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("10,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("11,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("12,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("13,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("14,2200,50");
Serial.write(0x03);
Serial.write(0x02);
Serial.print("15,2200,50");
Serial.write(0x03);
your suggestion/comment is highly appreciated. tnx
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
