I bought one of LEDSEE's new 16 channel FET controllers to drive some high power LEDs. The details on the web page show it dealing with some high current / voltages. Detail below:
Unfortunately the technical specs downloaded from the above page don't match with the sales info on the product page and state lower voltages being supported - useless for what I need.
Two questions:
Has anyone else used this board and if so you do know if it runs at 12V or so to drive high power LED automotive LEDs. How did you use it - configs, pin settings, what connects to what etc...
How do you wire it to a Arduino (micro) and programme it? I don't want to trust the manual as it seems like its for a generic (other product) and I always like to look through a few samples of code to see how it it implemented in real projects.
I hope someone can help as LEDSEE haven't responded to my queries.
couple of things. first, better to use tinyurl.com to make a tiny url, or post the part number of order number, even better yet, the linnk to the data sheet.
now, about that board.....
16 channels, with 15 pairs of screw terminals. .........
it is not a shield, it is a "schield"
and there are only 8 switches
3 glaring errors on the one page
the biggest offense is that there is no data sheet.
no reason you could not use 12V for an LED, then use a dropping resistor go get power to the LED and if it goes
power => LED => Resistor = > pin,
well, the voltage on the pin will be less than 5 volts. so that part is workable.
@dave-in-nj.
I think one screw per output, one or more commons, and some terminals connected to other Arduino pins.
I agree with the "no datasheet" part. This is a useless product for most of us without the proper documentation and schematic diagram.
Ratbag:
Seems to be a shield for short pieces of LED strip (<1Amp), or for low power LEDs.
High power LEDs need switching CC LED drivers.
Unless you don't mind the heat from a bank of current limiting resistors.
Attached is a homegrown 16-channel PCA9685 board with 16 switching CC drivers.
Very efficient (little or no heat).
Leo..
Wawa: @dave-in-nj.
Leo..
Wow that is an amazing bit of work you achieved with that board! It looks like the type of board I thought I was buying!
Wawa: @dave-in-nj.
Leo..
benscammell:
Great PCB, please can I have the schematic?
The boards I make are for 1-3watt LEDs, up to six in a string.
Might not be right for the 24volt/2Amp you're talking about.
Post a link to the LEDs you have.
There might be other solutions.
Leo..
