Hello, I am an arduino newbie and I am doing my first projects, one of them is to control a board with 16 relays, which I make work perfectly with 16 buttons.
https://www.az-delivery.de/es/products/16-relais-modul
My goal is that when I press a switch, the relay stays active indefinitely, which I achieve by doing "while", but the only way I can reset the entire board is by resetting the arduino.
My question is, would there be a way to reset just the relay without resetting the entire arduino?
I'm trying to put a button in A0
// Pines de los Reles
const int RELE1 = 23; // Arduino Pin 23
const int RELE2 = 25; // Arduino Pin 25
const int RELE3 = 27; // Arduino Pin 27
const int RELE4 = 29; // Arduino Pin 29
const int RELE5 = 31; // Arduino Pin 31
const int RELE6 = 33; // Arduino Pin 33
const int RELE7 = 35; // Arduino Pin 35
const int RELE8 = 37; // Arduino Pin 37
const int RELE9 = 39; // Arduino Pin 39
const int RELE10 = 41; // Arduino Pin 41
const int RELE11 = 43; // Arduino Pin 43
const int RELE12 = 45; // Arduino Pin 45
const int RELE13 = 47; // Arduino Pin 47
const int RELE14 = 49; // Arduino Pin 49
const int RELE15 = 51; // Arduino Pin 51
const int RELE16 = 53; // Arduino Pin 53
// Pines de los pulsadores
const int PULSADOR1 = 50; // Pin 50
const int PULSADOR2 = 52; // Pin 52
const int PULSADOR3 = 46; // Pin 46
const int PULSADOR4 = 48; // Pin 48
const int PULSADOR5 = 42; // Pin 42
const int PULSADOR6 = 44; // Pin 44
const int PULSADOR7 = 38; // Pin 38
const int PULSADOR8 = 40; // Pin 40
const int PULSADOR9 = 34; // Pin 34
const int PULSADOR10 = 36; // Pin 36
const int PULSADOR11 = 30; // Pin 30
const int PULSADOR12 = 32; // Pin 32
const int PULSADOR13 = 26; // Pin 26
const int PULSADOR14 = 28; // Pin 28
const int PULSADOR15 = 22; // Pin 22
const int PULSADOR16 = 24; // Pin 24
// Pin reset
const int BOTONRESET = A0; // Pin A0
pinMode(BOTONRESET, INPUT_PULLUP);
pinMode(PULSADOR1, INPUT_PULLUP);
pinMode(PULSADOR2, INPUT_PULLUP);
pinMode(PULSADOR3, INPUT_PULLUP);
pinMode(PULSADOR4, INPUT_PULLUP);
pinMode(PULSADOR5, INPUT_PULLUP);
pinMode(PULSADOR6, INPUT_PULLUP);
pinMode(PULSADOR7, INPUT_PULLUP);
pinMode(PULSADOR8, INPUT_PULLUP);
pinMode(PULSADOR9, INPUT_PULLUP);
pinMode(PULSADOR10, INPUT_PULLUP);
pinMode(PULSADOR11, INPUT_PULLUP);
pinMode(PULSADOR12, INPUT_PULLUP);
pinMode(PULSADOR13, INPUT_PULLUP);
pinMode(PULSADOR14, INPUT_PULLUP);
pinMode(PULSADOR15, INPUT_PULLUP);
pinMode(PULSADOR16, INPUT_PULLUP);
pinMode(RELE1, OUTPUT);
pinMode(RELE2, OUTPUT);
pinMode(RELE3, OUTPUT);
pinMode(RELE4, OUTPUT);
pinMode(RELE5, OUTPUT);
pinMode(RELE6, OUTPUT);
pinMode(RELE7, OUTPUT);
pinMode(RELE8, OUTPUT);
pinMode(RELE9, OUTPUT);
pinMode(RELE10, OUTPUT);
pinMode(RELE11, OUTPUT);
pinMode(RELE12, OUTPUT);
pinMode(RELE13, OUTPUT);
pinMode(RELE14, OUTPUT);
pinMode(RELE15, OUTPUT);
pinMode(RELE16, OUTPUT);
Serial.println(digitalRead (BOTONRESET));
int ESTADOBOTONRESET = digitalRead(BOTONRESET);
int ESTADOPULSADOR1 = digitalRead(PULSADOR1);
int ESTADOPULSADOR2 = digitalRead(PULSADOR2);
int ESTADOPULSADOR3 = digitalRead(PULSADOR3);
int ESTADOPULSADOR4 = digitalRead(PULSADOR4);
int ESTADOPULSADOR5 = digitalRead(PULSADOR5);
int ESTADOPULSADOR6 = digitalRead(PULSADOR6);
int ESTADOPULSADOR7 = digitalRead(PULSADOR7);
int ESTADOPULSADOR8 = digitalRead(PULSADOR8);
int ESTADOPULSADOR9 = digitalRead(PULSADOR9);
int ESTADOPULSADOR10 = digitalRead(PULSADOR10);
int ESTADOPULSADOR11 = digitalRead(PULSADOR11);
int ESTADOPULSADOR12 = digitalRead(PULSADOR12);
int ESTADOPULSADOR13 = digitalRead(PULSADOR13);
int ESTADOPULSADOR14 = digitalRead(PULSADOR14);
int ESTADOPULSADOR15 = digitalRead(PULSADOR15);
int ESTADOPULSADOR16 = digitalRead(PULSADOR16);
int ESTADORELE1 = digitalRead(RELE1);
int ESTADORELE2 = digitalRead(RELE2);
int ESTADORELE3 = digitalRead(RELE3);
int ESTADORELE4 = digitalRead(RELE4);
int ESTADORELE5 = digitalRead(RELE5);
int ESTADORELE6 = digitalRead(RELE6);
int ESTADORELE7 = digitalRead(RELE7);
int ESTADORELE8 = digitalRead(RELE8);
int ESTADORELE9 = digitalRead(RELE9);
int ESTADORELE10 = digitalRead(RELE10);
int ESTADORELE11 = digitalRead(RELE11);
int ESTADORELE12 = digitalRead(RELE12);
int ESTADORELE13 = digitalRead(RELE13);
int ESTADORELE14 = digitalRead(RELE14);
int ESTADORELE15 = digitalRead(RELE15);
int ESTADORELE16 = digitalRead(RELE16);
if (ESTADOPULSADOR9 == LOW) digitalWrite(RELE1, LOW); //HIGH sin pulsar, LOW pulsado. //HIGH rele desactivado, LOW rele activado
else digitalWrite(RELE1,HIGH);
while(digitalRead(RELE1)==LOW);
if (ESTADOPULSADOR10 == LOW) digitalWrite(RELE2, LOW);
else digitalWrite(RELE2,HIGH);
if (ESTADOPULSADOR11 == LOW) digitalWrite(RELE3, LOW);
else digitalWrite(RELE3,HIGH);
if (ESTADOPULSADOR12 == LOW) digitalWrite(RELE4, LOW);
else digitalWrite(RELE4,HIGH);
if (ESTADOPULSADOR13 == LOW) digitalWrite(RELE5, LOW);
else digitalWrite(RELE5,HIGH);
if (ESTADOPULSADOR14 == LOW) digitalWrite(RELE6, LOW);
else digitalWrite(RELE6,HIGH);
if (ESTADOPULSADOR15 == LOW) digitalWrite(RELE7, LOW);
else digitalWrite(RELE7,HIGH);
if (ESTADOPULSADOR16 == LOW) digitalWrite(RELE8, LOW);
else digitalWrite(RELE8,HIGH);
if (ESTADOPULSADOR1 == LOW) digitalWrite(RELE9, LOW);
else digitalWrite(RELE9,HIGH);
if (ESTADOPULSADOR2 == LOW) digitalWrite(RELE10, LOW);
else digitalWrite(RELE10,HIGH);
if (ESTADOPULSADOR3 == LOW) digitalWrite(RELE11, LOW);
else digitalWrite(RELE11,HIGH);
if (ESTADOPULSADOR4 == LOW) digitalWrite(RELE12, LOW);
else digitalWrite(RELE12,HIGH);
if (ESTADOPULSADOR5 == LOW) digitalWrite(RELE13, LOW);
else digitalWrite(RELE13,HIGH);
if (ESTADOPULSADOR6 == LOW) digitalWrite(RELE14, LOW);
else digitalWrite(RELE14,HIGH);
if (ESTADOPULSADOR7 == LOW) digitalWrite(RELE15, LOW);
else digitalWrite(RELE15,HIGH);
if (ESTADOPULSADOR8 == LOW) digitalWrite(RELE16, LOW);
else digitalWrite(RELE16,HIGH);
