So, I wanted to push this tutorial to its limits, making 16 touch sensors (I'm using screws for that)
http://www.arduino.cc/playground/Code/CapacitiveSensor
And using a 16 channel analog multiplexer (this is the one I actually tested with)
So far so good, it works. But I just want to double check things out, to be sure it won't burn something after hours of usage. ![]()
Here's the test code I created, I'm just using an Arduino UNO + the multiplexer, nothing else. Thanks for any advice! 8)
#include "pins_arduino.h" // Arduino pre-1.0 needs this
volatile uint8_t* port;
volatile uint8_t* ddr;
volatile uint8_t* pin;
byte bitmask;
#define pinToMeasure 8
uint8_t values[16] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 };
uint8_t buttons[16] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 };
uint8_t buttonEvent[16] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 }; // 1 == normal push, 2 == hold push //
char printOut[16*2];
uint8_t counterIdle = 0;
#define oversample 8
#define sensitivity (4*oversample)
 for (char x=2; x<12; x++) pinMode(x, OUTPUT);
 for (char x=2; x<12; x++) digitalWrite(x, LOW);
Â
 port = portOutputRegister(digitalPinToPort(pinToMeasure));
 ddr = portModeRegister(digitalPinToPort(pinToMeasure));
 bitmask = digitalPinToBitMask(pinToMeasure);
 pin = portInputRegister(digitalPinToPort(pinToMeasure));
 memset(values, 0, sizeof(values));
 for (uint8_t y=0; y<oversample; y++)
  for (uint8_t x=0; x<16; x++)
   digitalWrite(2, bitRead(x,0)); digitalWrite(3, bitRead(x,1));
   digitalWrite(4, bitRead(x,2)); digitalWrite(5, bitRead(x,3));
  Â
   values[x] += readCapacitivePin();
 uint8_t buttonchanged = 0;
 {Â
  if (values[x] <= (sensitivity/2) && buttons[x] > 0)
   if (buttons[x] < 99) { buttonEvent[x] = 1; buttonchanged = 1; }
   buttons[x] = 0;
  else if (values[x] > sensitivity && buttons[x] < 120)
   buttons[x]++;
   if (buttons[x] == 99) { buttonEvent[x] = 2; buttonchanged = 1; }
Â
 if (buttonchanged)
  Serial.print(":");
   if (buttonEvent[x] == 1) Serial.print("#:");
    else if (buttonEvent[x] == 2) Serial.print("@:");
    else Serial.print("_:");
    buttonEvent[x] = 0;
  Serial.println("");
  counterIdle = 0;
Â
 counterIdle++;
 if (counterIdle > 100)
  Serial.println("");
  counterIdle = 0;
uint8_t readCapacitivePin()
 *ddr &= ~(bitmask); // Make the pin an input with the internal pull-up on
 *port |= bitmask;
 uint8_t cycles = 6;
 for(uint8_t i = 0; i < 6 ; i++) // Now see how long the pin to get pulled up
  if (*pin & bitmask){ cycles = i; break; }
Â
 *port &= ~(bitmask); // Discharge the pin again by setting it low and output
 *ddr |= bitmask;
 return cycles;
