16 x 16 Led Matrix under IR remote control with mouse pad
Just finished it this evening. The video shows 4 seamless cascadable 8x8 led matrix driven by Max7219. I found an IR remote that has a mouse pad on it, so I put these together. It is pretty cool given that it was done in a day, well, with help of LedControl lib.
http://player.youku.com/player.php/sid/XNTA2ODAwNDQ0/v.swf
I am planning to do a game, not sure what though, need some ideas.
Now with sprite drawing with my new led matrix control library that is FAST enough.
Sketch for above demo shown in video
// Written by Peter Y Lin, a.k.a MJKZZ
// Do whatever you want to do with this code but use this code at your own risk
#include <avr/io.h>
#include <avr/interrupt.h>
#include "LedMatrix.h"
#define TICK_IR_BREAK		5000
#define TICK_IR_ONE_MIN		400
#define TICK_IR_ONE_MAX		600
#define	MAX_IR_PULSE		24
#define MAX_IR_DATA			8
#define MAX_IR_REPEAT		1
#define	PIN_IR				2
#define IR_CODE_UP			0xC500
#define	IR_CODE_DOWN		0xC480
#define IR_CODE_LEFT		0xC560
#define IR_CODE_RIGHT		0xC460
#define IR_CODE_UPLEFT		0xC562
#define IR_CODE_UPRIGHT		0xC462
#define IR_CODE_DOWNLEFT	0xC566
#define	IR_CODE_DOWNRIGHT	0xC466
#define IR_CODE_UPARROW		0xC590
#define IR_CODE_DOWNARROW	0xC4D0
#define IR_CODE_LEFTARROW	0xC430
#define IR_CODE_RIGHTARROW	0xC420
volatile unsigned int		g_tkPulse	= 0;
volatile unsigned int		g_ctPulse	= 0;
volatile unsigned int		g_arPulse[MAX_IR_PULSE];
volatile unsigned int		g_irCode	= 0;
volatile unsigned int		g_irTemp	= 0;
volatile unsigned int		g_ctCode	= 0;
LedMatrix					ledDisplay	= LedMatrix(5, 6, 7, 16, 16);
// This is a bitmap for a sprite
// The first two bytes specify width and height of
// sprite and the rest are bitmaps for sprite
byte g_sprite[6] =
	0x03,		// width
	0x04,		// height
	0b10110000,
	0b01001000,
	0b01000100,
	0b10100010,
volatile unsigned char		g_x		= 0;
volatile unsigned char		g_y		= 0;
void isr_ir()
	g_tkPulse	= TCNT1;
	TCNT1		= 0;
	if (g_tkPulse > TICK_IR_BREAK)
		g_ctPulse = 0;
	else if (g_ctPulse < MAX_IR_PULSE)
		g_arPulse[g_ctPulse] = g_tkPulse;
		g_ctPulse++;
		if (g_ctPulse == 16)
			g_irTemp = 0;
			for(int i=0; i<g_ctPulse; i++)
				if (g_arPulse[i] > TICK_IR_ONE_MIN && g_arPulse[i] < TICK_IR_ONE_MAX)
					g_irTemp |= 1;
				g_irTemp = g_irTemp << 1;
			if (g_irTemp == g_irCode)
				if (g_ctCode < MAX_IR_REPEAT)
					g_ctCode++;
				g_ctCode = 1;
			g_irCode = g_irTemp;
	TCCR1A = 0b00000000;
	TCCR1B = 0b00000011;    // Clk*64 = 4uS
	TCCR1C = 0b00000000;
	pinMode(PIN_IR, INPUT);
	attachInterrupt(0, isr_ir, FALLING);
	ledDisplay.init(8);
	ledDisplay.blank();
	ledDisplay.sprite(g_x, g_y, (const char *)g_sprite, 6, GRAPHIC_DRAW_SRC);
	ledDisplay.update();
	if (g_ctCode == MAX_IR_REPEAT)
		//Serial.print("Code = ");
		//Serial.println(g_irCode, HEX);
		ledDisplay.sprite(g_x, g_y, (const char *)g_sprite, 6, GRAPHIC_DRAW_XOR);
		switch(g_irCode)
		case IR_CODE_LEFT:
		case IR_CODE_LEFTARROW:
			if (g_x)
				g_x--;
		case IR_CODE_RIGHT:
		case IR_CODE_RIGHTARROW:
			if (g_x < ledDisplay.getWidth()-3)
				g_x++;
		case IR_CODE_UP:
		case IR_CODE_UPARROW:
			if (g_y)
				g_y--;
		case IR_CODE_DOWN:
		case IR_CODE_DOWNARROW:
			if (g_y < ledDisplay.getHeight()-4)
				g_y++;
		case IR_CODE_UPLEFT:
			if (g_y)
				g_y--;
			if (g_x)
				g_x--;
		case IR_CODE_UPRIGHT:
			if (g_y)
				g_y--;
				g_x++;
		case IR_CODE_DOWNLEFT:
				g_y++;
			if (g_x)
				g_x--;
		case IR_CODE_DOWNRIGHT:
				g_y++;
				g_x++;
		Serial.println(g_x, DEC);
		g_irCode = 0;
		g_ctCode = 0;
Very cool. Thanks for sharing!
Geoff
I’m trying the library with your eBay matrix module, i have simplifyed the code for only drawing an expanding / contracting rectangle
#include <avr/io.h>
LedMatrix  				ledDisplay	= LedMatrix(51, 53, 52, 16, 16);
  ledDisplay.init(8);
  ledDisplay.blank();
  for (int i=0;i<16;i++) {
   ledDisplay.rectangle(0,0,i,6,1);
   Serial.println(i);
   delay(50);
  for (int i=16;i>0;i--) {
   ledDisplay.rectangle(0,0,i,6,0);
   Serial.println(i);
   delay(50);
  ledDisplay.blank();
I have only 2 modules cascaded,
when matrix is defined 16x16 it work
when matrix is defined 16x8
LedMatrix(51, 53, 52, 16, 8);
all the two matrix show the same thing and
when matrix is defined 8x16
LedMatrix(51, 53, 52, 8, 16);
only one matrix module (on the left) work.
Probably you not intend develop the library for use it rectangular matrix, but if a day you want make the work… :slight_smile:
