I note from the Fritzing wiring picture that the backlight illumination led receives 5V. This may damage the display. Please place a 220 ohm resistor in the 5V wire to pin nr. 15 ('A') of the LCD display
A quick image search with Google reveals that her main problem stems from the fact that she is relying on an Instructable as her source.
As you can infer by the connections the LCD contrast is being provided by PWM, and the code reveals that this is the case. I did not notice any mention of the possible need to to adjust the output which is most likely incorrect for this particular display.
Paul's suggestion to connect pin 3 of the LCD to GND will determine if this is the only problem. @Codegirl21 - disconnect the blue wire from Digital pin 6 and connect it to GND.
As far as the backlight goes we can hope that there is a current limiting resistor on the pc board. Connecting the 220 ohm resistor as suggested above would be good insurance if that is not the case.
I just realized that there is another problem that will show up as soon the contrast is fixed.
There should either be a considerable delay added to loop() or, since the text is not changing, all of the code that is in loop() should really be in setup() and loop() should be empty.
photoncatcher:
Extremely unlikely if this is one of the common, almost universal "1602" displays.
If resistor "R8" is "101" - 100 Ohms, then the illumination LED will be drawing about 25 mA. You do not need any series resistor - unless of course, the display is too bright for you!
Zoom
Sometimes R9.
floresta:
Actually, with display pin 3 connected to Arduino pin 6, the correct way to make the code work is to use
