1602A LCD display strange characters after few seconds
To test the 1602A LCD, I used the following tutorial:
http://www.toptechboy.com/arduino/lesson-20-arduino-lcd-project-for-measuring-distance-with-ultrasonic-sensor/
I use an Aruino Uno R3 with the 1602A LCD display
Everything works fine for a while.
After 1 minute, the dimmer of the lcd changes (too high or too low)
So I adjust the potentiometer and it works fine again.
But after few seconds, the display shows strange characters (unreadable)
So I unplug the USB for a few minutes and set it again.
Hurray, it works again ... for a few seconds >:( (max 30 sec)
(and I can repat the process again & again)
Can it be a problem when I soldered the connectors to the display ?
Thanks for your help
Philippe
It sounds more like a power supply problem to me, possibly caused by an error in your wiring (which would include soldering problems).
Can you provide a photograph of your setup including an overhead view of everything and a closeup of your soldering?
Don
Today, I bought a new LCD: gmd1602a lcd xiamen ocular.
I changed the voltage from 5V to 3.3 V.
Same result, after 10 seconds, the second row disappears and replaced progressively by stange characters.
Display is OK for 10 seconds
Example after 10 seconds
Overview
Detail
Setup
Version 1: as dislayed in the picture
Version 2: replace 5v to LCD by 3.3V
Rgds,
Philippe
I see that you have a yellow jumper connecting the two halves of one of your breadboard power rails but I don't see a corresponding jumper on the other rail. If your power rails are indeed separated by a gap this could be your problem.
I have seen worse soldering but there still may be some problems with yours. You certainly don't need any more solder but it wouldn't be a bad idea to reheat some of your joints and get the fillet to completely surround the pins as they come through the pc board.
Don
Well, I can't see any suggestion of RAM overflow in the code.
Put a 47 µF capacitor between pins 1 and 2 of the LCD.
floresta:
Don
Just curious - how does fritz (ing ) knows that the peg board HAS TWO power rails?
The yellow jumper connect ONLY ground rails together !
The LCD has no power to the controllerr , only the contrast has power.
@Vaclav
I cannot figure out why you have responded to my post but I will respond to yours!
I don't know anything about fritzing. I didn't look at his fritzing diagram because that merely indicates what he is trying to do, not necessarily what he actually did do.
We do not know if his breadboard does or does not have a gap in the power rails. Some do and some don't. Therefore we cannot state for sure whether he has an extra jumper or a missing jumper.
Your last statement is only correct if there are indeed gaps present and I am inclined to believe that this is actually the case. We won't know for sure until Philippe returns.
Don
Disconnect your back light. You don't know how much resistance (or at all) the back light LED is in series with. It may be drawing too much current. Also disconnect your sonic ranger, see if your display lasts for longer. Ranging with ultrasound takes a lot of instantaneous power. If the power wire is anywhere near a display data wire, it interferes with the display.
Dear all,
Thank you for your answers.
As proposed by Floresta "it wouldn't be a bad idea to reheat some of your joints and get the fillet to completely surround the pins as they come through the pc board."
And now every thing works perfectly (the first LCD as well as the second one).
Concerning the yellow missing jumper:
In version 2: I used the left part of the breadboard with 3.3V and the right side with 5V because I saw on the LCD sheet that voltage is 3.3V for the second LCD. It was a bad idea so I removed the 3.3V and added the jumper to provide 5V.
Thanks to all,
Philippe
Thanks for the update.
So you connected the +5V to the "left" , next to the ground yellow jumper.
Where was your connection to the 3.3 V you have removed?
