16MHz vs 8MHz internal and IRLib
Hi, not sure if this is the right forum but here goes.
I have built a PWM controller for some LEDs that are controlled via an IR remote. It all works absolutely dandy on an Uno at 16Mhz but if I compile and upload to a stand alone 328P using the internal oscillator then the receiver is unresponsive. I know the program is running fine as the LED's behave properly. I am using an internal oscillator on breadboard board definition. I highly suspect that the IRLib timings are way off and I will have to run my final design at 16MHz but I want to understand a few things.
When compiling, do libraries assume that the AVR is a 16MHz?
If not, is this something that is set in board definitions and the one I have could be innacurate? (I downloaded the board def and I cannot remember where from)
Is 8MHz just simply to slow for decoding the signal?
Thank you!
In the Arduino IDE, you MUST select the appropriate "board" option under the "Tools" menu, which informs the compiler of the CPU clock speed.
I have a board definition for a 328P on breadboard with internal clock, but as I say I have no idea where I got it from. I will see if I can find a better one as it seems there is not a built in definition for what I am after.
(deleted)
Brilliant, it didn't work with that definition but it did get me poking around at the board definitions and noticed my fuses were set differently to the definitions. I am now up and running, thanks so much for your help :slight_smile:
Thanks, this is just what i needed. I had changed the board type but it was assuming it was 5V 16Mhz mini, I have 3.3V 8Mhz minis. After changing the processor type irlib2 worked great on the mini pro.
