16x16 Matrix, message and rain code, help.
Hi, Need some help. Newbie, I have some code to display random pixels on-off (rain) and I have a message that want to display after the rain or before. however it seems that the message does not scroll correctly. I am attaching code hopefully a genius could guide me in the right direction.
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
// DATA PIN
// If you want to use a different data pin on your microcontroller CHANGE THIS!
#define DATA_PIN 6
//used for long message
#define arr_len( x )  ( sizeof( x ) / sizeof( *x ) )
// Matrix setup params
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(16, 16, DATA_PIN,
NEO_MATRIX_TOP    + NEO_MATRIX_RIGHT +
NEO_MATRIX_ROWS + NEO_MATRIX_PROGRESSIVE + NEO_MATRIX_ZIGZAG,
NEO_GRB            + NEO_KHZ800);
// Edit this
// The important stuff, your message and colors
char* Text[]= {"Hello Friends","Welcome To","Need","some","help.","please"," could,","use,","your services"};
const uint16_t colors[] = {
  matrix.Color(255, 0, 255), matrix.Color(100, 255, 0), matrix.Color(255, 255, 0),matrix.Color(0, 0, 255), matrix.Color(255, 0, 255), matrix.Color(0, 255, 255), matrix.Color(255, 255, 255)};
int brightness = 10;
// End Edit
int numMode = arr_len(Text)-1;
int numColor = arr_len(colors)-1;
int pixelPerChar = 4;
int maxDisplacement;
int mode = 0;
  matrix.begin();
  matrix.setTextWrap(false);
  matrix.setBrightness(brightness);
  matrix.setTextColor(colors[0]);
int y = 16;
int x = 16;
int pass = 0;
int line_pass = 0;
  // if mode greater than numMode reset
  if (mode > numMode) { mode = 0; }
  matrix.fillScreen(0);
  matrix.setCursor(x, 0);
  scroll(Text[mode],10);
   //delay(300);
    rain(5, 20);
void clear() {
  for(int i=0;i<256;i++){
    matrix.setPixelColor(i, matrix.Color(0,0,0));
// this does the magic of scrolling
void scroll(char* message,int delays) {
  maxDisplacement = strlen(message) * pixelPerChar + matrix.width();
  if(++line_pass > matrix.width()) line_pass = 0;
  matrix.print(String(message));
  if(--x < -maxDisplacement) {
    x = matrix.width();
    if(++pass >= numColor) { pass = 0;  };
    matrix.setTextColor(colors[pass]);
    mode++;
  matrix.show();
  delay(delays);
//rain
void rain(int cycles, int delayTime) {
  int rain[] = {0,0,0,0,0,0,0,0};
  int values[] = {0,0,0,0,0,0,0,0};
  for (int v=0; v<16; v++) {
    values[v] = random(0, 10) * 10;
  for (int c=0; c<cycles; c++) {
    for (int f=0; f<10; f++) {
      for (int col = 0; col < 16; col++) {
        int row = map(values[col], 0, 100, 0, 16);
        if ((row % 2) == 1) {
          matrix.setPixelColor((256-row*16)+(7-col), matrix.Color(200,200,200));
          matrix.setPixelColor((256-row*16)+col, matrix.Color(200,200,200));
     matrix.show();
      delay(delayTime);
        values[v] = (values[v] + 10) % 100;
      matrix.clear();
      delay(100);
