16x2 Display displays random symbols after a few iterations.
I've pasted the relevant part of my code below. The DoControl command is part of the PID library. Every ten seconds, I command it to log the input, and output in percent to the screen. However, it will often display random symbols, scroll these random symbols, and make it impossible to interface with the screen. However, it will often return to normal after several more iterations of the while loop. I am uncertain what is causing this. Thanks.
void Run()
startTime = millis();
lastLogTime = millis();
lcd.clear();
lcd.setCursor(0,0);
//Write Set Point to Screen
lcd.print("Sp: ");
lcd.print(Setpoint);
lcd.write(1);
lcd.print("C ");
SaveParameters();
myPID.SetTunings(Kp,Ki,Kd);
while(true)
buttonStateRight = digitalRead(buttonPinRight);
buttonStateLeft = digitalRead(buttonPinLeft);
if (buttonStateRight == buttonStateLeft && buttonStateRight == HIGH)
delay(200);
opState = MENU;
return;
if (tuning)
lcd.clear();
lcd.print(F("Tuning..."));
DoControl();
if (millis() - lastLogTime > logInterval)
//Write Input To Screen
lcd.setCursor(0,1);
lcd.print(Input);
lcd.write(1);
lcd.print("C : ");
//Write output percent to Screen
float pct = map(Output, 0, WindowSize, 0, 1000);
lcd.setCursor(10,1);
lcd.print(pct/10);
//lcd.print(Output);
lcd.print("% ");
//Log Data to Serial
Serial.print((millis() - startTime)/10000);
Serial.print(" ");
Serial.print(Input);
Serial.print(" ");
Serial.print(Output/100);
Serial.print(" ");
Serial.println(Setpoint);
delay(100);
Maybe so and maybe not.
You really should post all of your code, and you should enclose your code in 'code' tags (use the octothorpe symbol).
Don
      lcd.write(1);
lcd.print("C : ");
My crystal ball tells me that you are using a custom character for the 'degree' symbol. You might want to see if your LCD controller already has such a symbol. Typically it is at address 0xDF.
Don
