16x2 display not displaying text only white boxes on top row
I got a 16x2 display, lcd name(QPASS 160A), and using an uno r3 clone from kuman
LCD ARDURINO
1 gnd
2 5v
3 gnd
4 7
5 gnd
6 8
11 13
12 12
13 11
14 10
15 5v
16 gnd
and this code:
#include <LiquidCrystal.h>
//LiquidCrystal lcd(RS, E, D4, D5, D6, D7);
LiquidCrystal lcd(7, 8, 10, 11, 12, 13);     // put your pin numbers here
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
 lcd.clear(); // Clear the screen
// Turn off the display:
lcd.noDisplay();
 // Turn on the display:
lcd.display();
// Print a message to the LCD.
lcd.print("hello, world!");
delay(5000);
but no luck just white boxes, tired all kind of wirings and code but nothing so far.
any help will be appropriated.
If your wiring is as described in the message, your constructor would be:
LiquidCrystal lcd(7, 8, 13, 12, 11, 10);     // put your pin numbers here
Your wiring is up to you. Quite honestly, life is easier when the wires are in the same order as the Uno pins. e.g. 7, 8, nc, 10, 11, 12, 13 (just like in your original constructor)
If in doubt, copy the example wiring exactly.
David.
david_prentice:
David.
thanks for the replay.
tried changing the constructor still white squares, any other advice?
Yes, post a clear photo of your wiring.
Note that breadboards and wires can be broken internally. Check with DMM.
Soldered joints may be soldered badly.
David.
david_prentice:
David.
I think I'll try re soldering the headers, since I don't have a DMM at hand.
I doubt the breadboard or wires a faulty since they are brand new, and I have rechecked my wiring a lot, is there a way to recognize a defected display?
Most items arrive in full working order (if sensibly packed).
If you don't have a DMM, just replace one jumper wire at a time. Or test each wire with an LED and resistor. e.g. put LED and resistor on breadboard. Test each wire by connecting LED to 5V via your wire.
David.
... is there a way to recognize a defected display?
If you are seeing white boxes then it is unlikely that your display is defective.
You can test your jumper wires using the LCD backlight instead of using an external LED.
Don
I had a similar problem but I was able to see the text behind the white squares. For me adjusting the potentiometer at the back of the I2C board helped. Did you try that ?
He would have to buy an I2C adapter board first.
Don
Not all LCD are created equal, I would get a variable resistor and try it. One leg to GND, other leg to 5v, and middle leg (wiper) to pin 3 of the LCD and play around it a bit. It is possible you can't see the text because the contrast is too high causing all blocks to be visible.
Tried that but still only boxes.
floresta:
Don
checked all wires with an external LED, all wires work fine but still no text. any other soultion?
I rewired according to https://www.arduino.cc/en/Tutorial/HelloWorld
david_prentice:
David.
... I rewired according to https://www.arduino.cc/en/Tutorial/HelloWorld
How about providing a photograph of your setup along with a copy of your current program so we can verify this?
Don
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  lcd.begin(16, 2);
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.pr
That's half of what we need. Where's the photo?
Don
floresta:
Don
it is in the replay you can't see it?
I uploaded it again hope you see it now
Look at the red and blue lines on your solderless breadboard.
Notice that there is a gap in each of the lines at the center of the board.
This means that there is also a gap in the corresponding bus bars.
Jumper the gaps and try your program again.
Don
if I understood you correctly it made no difference, FYI I can't see boxes right know only change brightness.
