I have tried the millis function but not really sure how to use it.
Could someone point me in the right direction so I can try and figure it out for my self, please?
Mike.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
const int buttonPin = 2; // The pin that the pushbutton is attached to
const int valvepin = 1; // The pin that the valves are attached to
// Variables will change:
int buttonState; // Current state of the button
int lastButtonState; // Previous state of the button
bool valveStatus;
#define BACKLIGHT_PIN 3
Serial.begin(9600); // Setup serial
// Initialize the button pin as a input with pullup, active low
pinMode(buttonPin, INPUT_PULLUP);
//Initialize button states
buttonState = digitalRead(buttonPin);
lastButtonState = buttonState;
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
lcd.setBacklight(HIGH);
lcd.begin(16, 3);
lcd.setCursor(0, 0);
lcd.print(" !!!WELCOME!!! ");
lcd.setCursor(0, 1);
lcd.print("Valves Resetting ");
delay(3000);
lcd.clear();
Serial.println("Exhaust Valves ");
// Read the pushbutton input pin:
// Compare the buttonState to its previous state
if (buttonState != lastButtonState) //Changed
if (buttonState == LOW) //New press, so change valve flag
valveStatus = !valveStatus;
delay(50);
lastButtonState = buttonState; // Save the current state as the last state, for next time through the loop
if (valveStatus) //Positions the valve
Serial.write(0x56);
Serial.write(0x31);
Serial.write(0x0A);
Serial.print("Valve Status: ");
Serial.print(" Valve Open");
Serial.println(" (Loud Mode)");
lcd.print("Valves Open ");
lcd.print("(Loud Mode) ");
Serial.write(0x56);
Serial.write(0x30);
Serial.write(0x0A);
Serial.print(" Valve Closed");
Serial.println(" (Quiet Mode)");
lcd.print("Valves Closed ");
lcd.print("(Quiet Mode) ");
s200bym:
Sure!
You have a "loop" that repeats over and over; the only delay is that 50 ms you are using as an extremely crude and dodgy de-bounce - but that is another matter.
So you can insert other useful code that follows the rules - no delay() - at the end.
Common pieces of code such as
should be in a separate function. In that function, you also set a boolean flag TRUE and a counter (unsigned long) to the current millis().
At the end of the loop, you check the boolean flag. If TRUE (which is just "if flag"), you subtract the counter from the current millis() and if the result is >= your desired illumination time (unsigned long), you turn the backlight off.
I may sound stupid but I am completely lost. i am really struggling to get this coding
#include <Wire.h>
bool valveStatus;
#define BACKLIGHT_PIN 3;
unsigned long currentMillis ();
boolean TRUE;
boolean counting;
unsigned long timeOut = 15000;
lcd.begin(16, 3);
delay(3000);
lcd.clear();
delay(50);
Serial.write(0x56);
Serial.write(0x31);
Serial.write(0x0A);
Serial.write(0x56);
Serial.write(0x30);
Serial.write(0x0A);
{ if (TRUE) timeOut >= currentMillis;
I started to write it for you, but I could not figure out what <LiquidCrystal_I2C.h> library you were using. The one in the basic install and the one in the library manager do not like the reference to "POSITIVE". I will need some more spare( ) time to have another go at it.
A few comments not related to the issue but related to the use of the fm's newLiquidCrystal library API functions.
The deprecated function:
should no longer be used.
And when using the full constructor with all the parameters, as you have done, it is not needed since you have already specified that information in the constructor (see the last two parameters?).
setBacklightPin() was used before the constructor supported specifying the pin and control information.
There is no need for it. Just delete that line.
You cannot use any of the LCD library API functions prior to calling begin().
i.e you have called setBacklight(dimlevel) before calling begin(). That won't work since the library does not yet know what pins are used to control the backlight.
You are incorrectly using the function setBacklight(dimlevel)
That functions takes a 0-255 dimlevel not HIGH/LOW. It is used to control the backlight brightness, not to turn it full on/off.
Using a value of HIGH which is defined as 1 is telling the library to make the backlight as dim as possible.
Since the device you have doesn't support dimming, the library will set the brightness as low as it can which is full brightness. However, if you were to change the LCD to another device like a LCD keypad and set a brightness of 1, it would be very dim.
I would recommend that you not use setBacklight().
If you want to turn the backlight full on/off you should use:
backlight() and noBacklight() to turn the backlight on/off.
In terms of how to turn off the LCD; after your elapsed time has passed, simply call lcd.noBacklight()
Paul__B:
Thanks Paul__b,
I'm using fm's newLiquidCrystal library.
Instead of writing me the code, would you be able to write just the commands and I have a go at trying to put it all in the right place?
#include <Wire.h>
int period = 15000;
unsigned long time_now = 0;
bool valveStatus;
lcd.begin(16, 3);
delay(3000);
lcd.clear();
lcd.backlight();
delay(50);
Serial.write(0x56);
Serial.write(0x31);
Serial.write(0x0A);
Serial.write(0x56);
Serial.write(0x30);
Serial.write(0x0A);
if(millis() > time_now + period){
time_now = millis();
lcd.noBacklight();
What you have is a system which regularly switches the backlight off every 15 seconds, irrespective of whether you pushed a button or not. The two adjustments I suggested are that you synchronise this to when you actually press the button by adding
into where you set
lcd.backlight();
and also set a flag to mark when you set the backlight on and only use the code to turn it off when it actually was on. This latter is obviously not critical.
into where you set
lcd.backlight();
What is the reason for this? I put it in place and it didn't makes any difference to the operation.
