16x2 issue. Please help
Hi, shopefully I did the code tags right this time. I have a 16x2 display on an UNO. Ive started making an AFR display. So far it is starting to work, but I have two problems:
1- I am having trouble getting it to refres or "read realtime". when I start it, it shows the current voltage but does not change with the pot. Ive tried writing the code to write blank spaced between readings, and have tried spacing in the " ". Im sure its just me lack of knowledge as I am very new at this.
2- Regardless of where I set the cursor at, the AFR reading always starts at block #2 on line 1. Any help would be greatly appreciated.
#include <LiquidCrystal.h>
 //LiquidCrystal lcd (8,9,4,5,6,7);
// const byte backLED = 3;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int lastAfr = 0;
int currentAfr = 0;
    pinMode(A1, INPUT);  // Set pin A8 as input for boost input
    pinMode(7, OUTPUT); // Red LED
    pinMode(8, OUTPUT); // Green LED
    //digitalWrite(backLED, LOW);
    lcd.begin(16, 2);
    lcd.setCursor(0,0);
    lcd.print("AFR module loading");
    delay(100);
    lcd.clear();
float afrValue = analogRead(A1);                     //Read input from LC1 Wideband voltage
                                                     //float afroutput = (afrValue-0)*(20-10)/(1023-0);
float afroutput = (afrValue-0) * (20-10) / (1023-0)+7;
lcd.setCursor(1,4);
lcd.print(afroutput);
delay(100);
lcd.setCursor(1,4);
lcd.print("       ");
delay(100);
lcd.setCursor(1,4);
// lcd.print("AFR  ");
   if (afroutput < 11) {
  digitalWrite(8, HIGH);       // Red LED for warmup
  lcd.setCursor(0,0);
  lcd.print("02 Sensor warmup");
  else {
    digitalWrite(8, LOW);
  while(float(afroutput)) {
    digitalWrite(7, HIGH);
    delay(5);
    digitalWrite(7, LOW);
  if (afroutput > 14.7){
     lcd.setCursor(0,0);
     lcd.print("**Warning Lean**");
     delay(100);
     lcd.setCursor(0,0);
     lcd.print("                ");
     delay(100);
     lcd.setCursor(0,0);
     delay(5);
lcd.setCursor(1,4);
You are trying to set the cursor to the fifth row of your two row display.
Try using lcd.setCursor(4,1);.
Don
Well there's one good answer. I was understanding the row and position wrong. I thought it was ; 1 for the row and 4 for the position from the left. Thank you!
