16x2 LCD animation wont run into for loop
Trying to make simple animations with a 16x2 lcd screen. code blocks will run properly when on there own but will not run when i try putting them into a for loop what am I doing wrong?
#include <LiquidCrystal.h>
int i =0;
LiquidCrystal lcd(10,9,5,4,3,2);
byte W1[8] = {
B00000,
B11000,
B11000,
B11100,
B11100,
B11100,
B10010,
B10001
byte W2[8] = {
B00000,
B01100,
B01100,
B01110,
B01110,
B01110,
B01010,
B10010
lcd.begin(16, 2);
lcd.createChar(0, W1);
lcd.createChar(1,W2);
lcd.write(byte(1));
Serial.println(i);
for(i = 0; i > 15; i++){
Serial.println(i);
lcd.setCursor(i,0);
lcd.write(byte(0));
lcd.clear();
++i ;
lcd.setCursor(i,0);
lcd.write(byte(1));
lcd.clear();
i=15;
for(i = 0; i > 15; i--){
lcd.setCursor(i,1);
lcd.write(byte(0));
lcd.clear();
--i;
lcd.setCursor(i,1);
lcd.write(byte(1));
lcd.clear();
--i;
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
i is initially set to 0, then the code within the if statement is only executed if the condition (i > 15) is true.
ok that makes sense I reversed the conditional and it started working right away thank you very much
