I have been working all day with my LCD screen using a variety of sketches and its been fine. I have a Adafruit ADLX355 accelerometer sketch I’ve amended so it records the data to an sd card. Even with no lcd.print’s I get nothing but:
DDDDDDDDDDDDDDDDDDDDDDd…etc
This is without any lcd statements. As soon as I add a “test” print it makes no difference. Ive tried shutting everything off and resetting, etc.
Here is my code:
#include <SD.h> // Include SD library for the micro sd
#include <LiquidCrystal.h>
int CS_pin = 4; // SD chip select
int id = 1; // Set the ID for the beginning of .csv file.
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int xInput = A0;
const int yInput = A1;
const int zInput = A2;
const int buttonPin = 8;
// Raw Ranges:
// initialize to mid-range and allow calibration to
// find the minimum and maximum for each axis
int xRawMin = 512;
int xRawMax = 512;
int yRawMin = 512;
int yRawMax = 512;
int zRawMin = 512;
int zRawMax = 512;
// Take multiple samples to reduce noise
const int sampleSize = 10;
lcd.begin(16, 2);
analogReference(EXTERNAL);
// Check if card is ready
if(!SD.begin(CS_pin)) {
Serial.println("Card Failed");
return;
Serial.println("Card Ready");
// Create a LOG.csv with headers
File logFile = SD.open("LOG.csv", FILE_WRITE);
if(logFile)
logFile.println(", , , ,"); // Leave a blank line
String header = "X, Y, Z";
logFile.println(header);
logFile.close();
Serial.println(header); // Send to the serial monitor
Serial.println("Couldn't create LOG.csv file");
int xRaw = ReadAxis(xInput);
int yRaw = ReadAxis(yInput);
int zRaw = ReadAxis(zInput);
if (digitalRead(buttonPin) == LOW)
AutoCalibrate(xRaw, yRaw, zRaw);
//Serial.print("Raw Ranges: X: ");
//Serial.print(xRawMin);
//Serial.print("-");
//Serial.print(xRawMax);
//Serial.print(", Y: ");
//Serial.print(yRawMin);
//Serial.print(yRawMax);
//Serial.print(", Z: ");
//Serial.print(zRawMin);
//Serial.print(zRawMax);
//Serial.println();
//Serial.print(xRaw);
//Serial.print(", ");
//Serial.print(yRaw);
//Serial.print(zRaw);
// Convert raw values to 'milli-Gs"
long xScaled = map(xRaw, xRawMin, xRawMax, -1000, 1000);
long yScaled = map(yRaw, yRawMin, yRawMax, -1000, 1000);
long zScaled = map(zRaw, zRawMin, zRawMax, -1000, 1000);
// re-scale to fractional Gs
float xAccel = xScaled / 1000.0;
float yAccel = yScaled / 1000.0;
float zAccel = zScaled / 1000.0;
Serial.print("X: ");
Serial.print(xAccel);
Serial.print(" Y:");
Serial.print(yAccel);
Serial.print(" Z:");
Serial.println(zAccel);
if(logFile)
logFile.print(xAccel);
logFile.print(",");
logFile.print(yAccel);
logFile.print(",");
logFile.println(zAccel);
logFile.close();
Serial.print(",");
Serial.print(",");
Serial.println("Couldn't open LOG.csv to write to file");
// Lastly, increment the ID number
id++;
delay(2000);
// Read "sampleSize" samples and report the average
int ReadAxis(int axisPin)
long reading = 0;
analogRead(axisPin);
delay(1);
for (int i = 0; i < sampleSize; i++)
reading += analogRead(axisPin);
return reading/sampleSize;
// Find the extreme raw readings from each axis
void AutoCalibrate(int xRaw, int yRaw, int zRaw)
Serial.println("Calibrate");
if (xRaw < xRawMin)
xRawMin = xRaw;
if (xRaw > xRawMax)
xRawMax = xRaw;
if (yRaw < yRawMin)
yRawMin = yRaw;
if (yRaw > yRawMax)
yRawMax = yRaw;
if (zRaw < zRawMin)
zRawMin = zRaw;
if (zRaw > zRawMax)
zRawMax = zRaw;
