16X2 LCD DISPLAY INTERFACED WITH ARDUINO UNO NOT DISPLAYING VALUES
I'm quite new to Arduino and I'm making a vital signs monitor for my final project using Arduino Uno. I will only be using a temp sensor LM35 and Heart rate sensor KY039 whose values I am displaying on an lcd display (16x2). The code compiles and uploads once I set my project up. However nothing appears on my LCD screen. It only lights up. I have also connected a push button that lights the LCD on and off.
Here is the code with explanations
/* This is the sketch for a vital signs monitor intended to senses temperature and heart rate*/
#include <LiquidCrystal.h> //Include LCD library
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //Connections to arduino pins
/*define*/
int HBSensor = 8; //the heart beat sensor is connected to pin 8 of arduino uno
int HBCount = 0;
int HBCheck = 0;
int TimeinSec = 0;
int HBperMin = 0;
int HBStart = 6; //button is connected to pin 6 on arduino
int tempPin = A1;
int TEMPERATURE = 0;
int val;
int LED = 7;// LED connected on this output pin
int run;//for pushbutton
int buttonPin;
float cel;//temperature celsius
/* void setup*/
  /*temp setup*/
  /*lcd setup*/
  lcd.begin(16, 2);// lcd display is type 16x2
  run = 0; //starts stopped pushbutton
  buttonPin = 6 ; //whatever pin your button is plugged into
  pinMode(HBSensor, INPUT); //heartbeat sensor
  pinMode(HBStart, INPUT_PULLUP);
  pinMode (tempPin,INPUT); //temperature sensor
  pinMode (LED,OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);//for pushbutton
  lcd.clear();//resets LCD display
  lcd.setCursor(0,0);
  lcd.print("Current HB  : "); //will display the current hb
  lcd.setCursor(0,1);
  lcd.print("HB per Min  : 0.0");
  lcd.setCursor(0,2);
  lcd.print("Current Temp  : "); //will display the current temperature reading
   lcd.print (TEMPERATURE);
   lcd.print ("C");
   delay(3000);
//multiple loops so i gave them different names
    pushbutton();
    heartrate();
    temp();
void pushbutton ()
//void loop 1 for pushbutton
     if(run == 0)
         run = 255;
         run = 0;
      if(run > 0)
     //code you only run if button was pressed, stops running when button pressed again, so forth...
  //void loop 2 for heartbeat
void heartrate ()
        HBCount = HBCount + 1;
        HBCheck = 1;
        lcd.display ();
        lcd.setCursor(14,0);// set cursor to this position on lcd
        lcd.print(HBCount);
        lcd.print(" ");
      if((digitalRead(HBSensor) == LOW) && (HBCheck == 1))
        HBCheck = 0;
      if(TimeinSec == 10)
          HBperMin = HBCount * 6; //10 seconds is multiplied by 6 to make one minute ie 60 secs
          lcd.setCursor(14,1);
          lcd.print(HBperMin);
          lcd.print(" ");
          lcd.setCursor(14,2);
          lcd.print ("*C");
          lcd.setCursor(0,2);
          lcd.print("Press Button again.");
          Serial.print("TEMPERATURE = ");
          Serial.print ("C");
          Serial.println("");
          Serial.print("HBperMin = ");
          Serial.println();
          HBCount = 0;
          TimeinSec = 0;
//void loop 3 for temperature sensor
void temp ()
val = analogRead(tempPin);//READ THE A1 PIN
float mv = ( val/1024.0)*5000; //MANIPULATE THE VALUE
float cel = mv/10;//DIVIDE BY 10
if(cel >= 39)
//blinks at 5ms intervals for 10 seconds when temperature is higher than 39
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
  if(cel <= 39)
    digitalWrite(LED,LOW); //switch LED off
