16x2 lcd print only 1 character
hi everyone
i’m working on project to display number using button. in this project i use two arduino mega where one for execute the arithmetic operation and another one for display. right now i’m at where i want to display number until 99. but i face a problem where lcd only display one digit. does anybody know what is the problem i am facing right now? and will be gratefull for the solution
here i attach the source code for both arithmetic and the for the lcd
int button1= 22;
int button2= 23;
int button3= 24;
int button4= 25;
int button5= 26;
int button6= 27;
int button7= 28;
int button8= 29;
int button9=30;
int button10=31;
int tambah=0;
int jawapan;
int baca;
int hantar;
int a;
int b;
int c;
int d;
int e;
int f;
int g;
int h;
int i;
int j;
unsigned char usButtonStatus(void);
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  pinMode(button3, INPUT);
  pinMode(button4, INPUT);
  pinMode(button5, INPUT);
  pinMode(button6, INPUT);
  pinMode(button7, INPUT);
  pinMode(button8, INPUT);
  pinMode(button9, INPUT);
  pinMode(button10,INPUT);
  pinMode(tambah, INPUT);
// Serial.print (hantar);
// delay (10000);
  baca:
if (digitalRead(button1)==HIGH);
   a = 0;
   delay(10);
 if (digitalRead(button1)==LOW)
  a=5;
 delay(10);
 if (digitalRead (button2) ==LOW && digitalRead (button3)==HIGH && digitalRead (button4)== HIGH && digitalRead(button5)==LOW)
  b = 1;
  c =0;
  d=0;
  e=0;
  delay(10);
 if (digitalRead (button2)==LOW && digitalRead (button3) == LOW  && digitalRead (button4)==HIGH && digitalRead (button5)==HIGH)
  b=1 ;
  c=1;
  d=0;
  e=0;
 delay(10);
 if (digitalRead (button2)==LOW && digitalRead (button3) == LOW  && digitalRead (button4)==LOW && digitalRead (button5)==HIGH)
  b=1;
 c=1 ;
  d=1;
  e=0;
 delay(10);
 if (digitalRead (button2)==LOW && digitalRead (button3) == LOW  && digitalRead (button4)==LOW && digitalRead (button5)==LOW)
  e=1;
  b=1;
  c=1;
  d=1;
 delay(10);
 if(digitalRead (button2)==HIGH && digitalRead(button3)==HIGH && digitalRead(button4)==LOW && digitalRead(button5)==LOW)
   e=0;
   b=0;
   c=0;
   d=0;
 if (digitalRead(button6)==LOW)
   f = 50;
   delay(10);
 if (digitalRead(button6)==HIGH)
  f=0;
 delay(10);
 if(digitalRead(button7)==LOW && digitalRead(button8)==HIGH && digitalRead(button9)==HIGH && digitalRead(button10)==HIGH)
   g=10;
   h=0;
   i=0;
   j=0;
   delay(10);
 if(digitalRead(button7)==LOW && digitalRead(button8)==LOW && digitalRead(button9)==HIGH && digitalRead(button10)==HIGH)
   g=10;
   h=10;
   i=0;
   j=0;
   delay(10);
  if(digitalRead(button7)==LOW && digitalRead(button8)==LOW && digitalRead(button9)==LOW && digitalRead(button10)==HIGH)
   g=10;
   h=10;
   i=10;
   j=0;
   delay(10);
 if(digitalRead(button7)==LOW && digitalRead(button8)==LOW && digitalRead(button9)==LOW && digitalRead(button10)==LOW)
   g=10;
   h=10;
   i=10;
   j=10;
   delay(10);
jawapan:
   hantar=a+b+c+d+e+f+g+h+i+j;
    delay (10);
// else
//   a = 0;
// delay (1000);
// } s
//while (digitalRead(tambah)==LOW)
if(usButtonStatus()==1)
 delay (10000);
 //goto baca;
// if (digitalRead(tambah)== LOW)
  //goto jawapan;
 //if(digitalRead (tambah)==HIGH)
  // goto baca;
 //if(digitalRead (tambah)==LOW)
  //goto jawapan;
   unsigned char nstatus = 0;
   unsigned char button_status = 0;
   if(digitalRead(10) == 1)
       do
         nstatus = digitalRead(10);
         button_status = 1;
       }while(nstatus);
   return button_status;
// include the library code:
#include <LiquidCrystal.h>
//int button=22;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup(){
    // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // initialize the serial communications:
//  pinMode(button,INPUT);
//  while (digitalRead (button)==LOW);
  // when characters arrive over the serial port...
  if (Serial.available()) {
    // wait a bit for the entire message to arrive
    // clear the screen
    lcd.clear();
    // read all the available characters
    while (Serial.available() > 0) {
      // display each character to the LCD
      lcd.write(Serial.read());
      Serial.println(Serial.read());
I have no idea what you are sending to the display, but there is a bug in the receiving code.
The two Serial.read () calls print every other character to the lcd. The serial monitor gets the missing ones.
You can replace it with something like
char val = Serial.read();
           lcd.write(val);
          Serial.println(val);
With this substitution, everything I type in the entry box of the monitor shows up in both places.
First my question is why you are using 2 arduino mega ?? It has more efficient digital ios to achieve using 1 mega board itself.
2) Send me your connection Diagram,
cattledog: I have no idea what you are sending to the display, but there is a bug in the receiving code.
           lcd.write(val);
great eyes you have. and yes it work. thank you very much
