when i send any character my lcd prints it but one strange character (4 horizontal lines) appears after that. what is the problem in code pls correct me.
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
lcd.begin(16, 2);
lcd.print("hello, world!");
lcd.setCursor(0, 1);
if(Serial.available()>0)
lcd.write(Serial.read());
a)
please edit your post and post your code in code tags
b)
I assume you close your serial input with a linefeed and/or Carriage return.
These might lead to the lines.
either don't send linefeed/Carriage return or just don't print non printable characters
char c = Serial.read();
if (c > 0x20) lcd.print(c);
untested.
thanks friend. it worked.
but can u explain me this "if (c > 0x20)". why did it solved my problem.
google for "ASCII Table".
You will see that the lowest printable character is the blank. it is dec 32 or 0x20 in hex
and now I see, you should use
c >= 0x20)
to include also the blanks. As alternative you could write
c >= ' ')
that will do the same.
system
Closed
August 8, 2022, 2:56pm
5
