16X32 display help
Hoping someone can help me, I am using 16x32 matrix and want to use a timer at the same time look for analog inputs(vibration sensor-qty 9) but because i am constantly sending data to update the matrix sometimes the vibration sensor does not register....if i increase SAMPLE_TIME2 my inputs register because i am not sending data to my matrix but then my timer will not be accurate... is there a driver out there where i can send data to start and stop the timer only?
int SAMPLE_TIME2 = 70;
unsigned long currentTime = 0;
if (millis() >= currentTime + SAMPLE_TIME2) {
      countDownNumber = countDownNumber + .1;
      matrix.fillScreen(1); // Clear background
      matrix.setTextSize(1);
      matrix.setTextColor(matrix.Color333(7, 7, 7));
      matrix.setCursor(2, 0);
      matrix.print(String(countDownNumber));
      currentTime = millis();
      matrix.swapBuffers(false);
Thanks for using code tags, but that's the only forum rule you have managed to follow. Where is your schematic? Where are the clickable links to your components? Where is your complete code? You have not even told us what type of Arduino you are using. Without those there is little hope anyone can help you, surely you can see that?
