17HS4023 stepper motor and 36820 driver
Will the 36820 driver and 17HS4023 with a 120v to 12v DC converter work? I've replaced both the motor and driver already, same results. It only works on high it shuts down quickly after becoming jittery. Any thoughts on this???
Scort
Request for Information to Help You:
I find your question interesting, but I have a problem understanding your setup. After reading your description, I still have no idea what your actual configuration looks like. To help you better, please provide the following:
  1. Annotated Schematic: Post a clear, annotated schematic of your setup showing all connections, including power, ground, and any power supplies. I do not work with Fritzing diagrams or unclear pictures. However, a readable photo of a hand-drawn schematic is perfectly fine.
  2. Technical Details: Provide links to the technical information for all hardware components used in your setup. There are many different and sometimes incompatible devices that look similar but behave differently, so it's crucial that we have accurate information. Avoid linking to marketplace sites like Amazon that often lack detailed specifications.
  3. Why This Matters: All you want is to make everything work together correctly, and all we want is to help you achieve that. By providing the correct details, we can offer more targeted and effective assistance.
Helpful Resources:
Please share these details so we can guide you toward the right solution. We're here to help!
