180348 DIY soldering station
Hi I'm new here and I might write in the wrong place but I bought a kit from the elector that was to be programmed and I installed IDE which I used to program an Arduino pro Micro without any problems - it worked immediately.
As they write: This is a compact soldering station for the Weller RT tips. Based on the idea of ​​the Platino Soldering Station, this one uses ATmega32u4 also found in the Arduino Leonardo
I have followed the instructions! In addition to the hardware that is ready-made, there are:
1:
Program code to be compiled and uploaded to the processor.
This I have done but the device's OLED display shows nothing.
2:
Completely compiled code (Intel HEX) that can be recharged with RADIO
but I am not familiar with that method.
IS IT ANYONE WHO CAN TAKE A LOOK AT THE CODE?
I cannot determine if it is correct or if it is incorrect but
there are strange spelling mistakes that make me suspicious.
I have been trying to reach Elektor's service for a month now but nothing happens.
I have googled on the subject but find absolutely NOTHING - it is as if I am the only one in the whole world who bought this kit.
(There is no kit in the right sense then only the OLED display and
rotary encoder must be connected.)
180348-11_V1_2.zip (191.7 KB ) Firmware 1.2 = compilerbar kod
180348-41_V1_2.zip (55.15 KB ) Precompiled Firmware 1.2
180348-11_V1_2(9).zip (192 KB)
180348-41_V1_2(8).zip (55.1 KB)
usbasp programmer + avrdudeprog or Khazama AVR Programmer or eXtreme Burner - AVR
You'll find everything on the internet
program HEX via K4,
function OK, greater sensitivity to soldering cable section (does not go into stby-100-C and OFF)
