Recently, I've become interested in running Arduino with these batteries / using them to upgrade existing battery powered items that previously took NiMh cells etc.
If I look on instructables, I see plenty of projects using these devices but also lots of comments about people creating "bombs" because they're not using the proper precautions.
Perhaps someone here can help clear things up?
I can see that it's possible to charge these devices either with a dedicated charger (e.g. https://www.gearbest.com/chargers/pp_365133.html), which deals with individual cells, or something like a TP4056 which, again, I think is only for charging individual cells.
Some people appear to be "paralleling up" 18650 cells and charging them with something like a TP4056 but I'm thinking that this isn't how it should be done.
So, what happens if I want to charge 2x 18650s in series? I think I need something like this: 2S 3A PCB Protection Board Li-ion Lithium Battery 18650 Charger Module 7.4V 8.4V | eBay which appears to allow connections to the anode and cathode of each cell connected in series which is then suitable for charging this pair of cells "individually."
Now, I also understand that discharging these cells too far can damage them or render them inoperable. This means that they shouldn't be discharged below 3V (?)
In this case, this needs a battery management circuit which looks at the voltage of each cell and, presumably, cuts off the output of the pack (if 2 batteries are in series) when this occurs (?) Again, something like that "2S 3A PCB Protection Board Li-ion Lithium Battery 18650 Charger Module 7.4V 8.4V | eBay" could be used for this providing that 8.4V is put onto the P+ P- pins ?
And those very same P+ and P- pins, once the battery pack has been charged, can presumably be used for the battery's load ?
Are those assumptions correct?
Is it also possible to pair up cells for these BMS boards or is that just asking for trouble?
Also, how do you know that these BMS boards have "charged" the battery pairing? There is no indication so it is a case of monitoring the current?
Thanks for any replies.
