18650 Internal Resistance Tester
I have next to no idea what Im doing just enough to get me in trouble
I copyed this sketch and changed the circuit and timer to load test for 10 seconds 18650 cells
im not sure why it is working without two voltage inputs across the load resistor but it seems to work ok
can someone help and look over this and tell me why I got this to work please
cheers
Brett
Arduino_Battery_Internal_Resistance_Meter_-_Changed2.ino (5.12 KB)
buzzliteyear:
If that were the case, indeed it wouldn't work.
Luckily you have the grounds connected.
thanks heaps for the reply
there wasnt many tester out there but what I did find everyone else tested across the main load resistor like this
https://adamwelch.co.uk/wp-content/uploads/2016/01/Arduino-Lithium-Capacity-Checker-v1.0_schem.png
They probably used a 4-terminal resistor, and then differential mode. That's indeed more accurate in this situation.
Never mind, my bad. I'm old. :confused:
Ok i just got my digital clamp meter today and looking for help with this line
v2 = (analogRead(vIn)*vCal)/1014; // get loaded battery voltage
it looks like the code is calculating at max amps but I want it to calculate at the end of the 10 second load test
how do I change this ?
cheers
Brett
Start the test, add a 10-second delay, do your measurement, and you have the current at the end of the 10-second test.
That function by the way very likely needs a division by 1024, not 1014, and you will want to force it to do a floating point calculation - e.g. by using 1024.0 instead of 1024.
thanks for reply
because i dont know what im doing I adjusted that figure to try match my volt meter but then worked out
the amps problem reading max and not lowest after 10 second test
this is what is there can you change it a show me
cheers
Brett
void ircalc(){                           // resistance calc function
 digitalWrite(xBase, LOW );              // switch in the load
 delay(10000);                                   // added 10 second load time
 v2 = (analogRead(vIn)*vCal)/1014;   // get loaded battery voltage      was 1023 ( adjusted for loaded voltage )
 i2 = v2/load;                                       // calculate loaded current
 digitalWrite(xBase, HIGH);               // switch out the load
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Hi Tom, thanks so much for the Welcome....
I have changed the code view thanks for that
also the png circuit in in the first post below left ( I hand drawn it in DIYLC with mouse)
load resistor upgraded to 50w seems to give more consistent readings
thanks heaps for looking
Cheers
Brett
