Hi all,
First time poster.
Perlin made the Perlin noise generator 2001 and then improved it to "Simplex noise" for less computional overhead and easier usage in higher dimensions, Simplex noise - Wikipedia
Here is very good explanation of the algoithm (from my old University, yay!): http://weber.itn.liu.se/~stegu/simplexnoise/simplexnoise.pdf
I ported the C# implementation by Benjamin Ward, GitHub - WardBenjamin/SimplexNoise: C# Simplex Noise (1D, 2D, 3D). Supports arbitrary sizes and scales.
Demo gif: Imgur: The magic of the Internet
#include <math.h>
float x;
int o3,o5,o6;
byte perm[] = { 151,160,137,91,90, 15,131, 13,201,95,96,
53,194,233, 7,225,140,36,103,30,69,142, 8,99,37,240,21,10,23,190, 6,
148,247,120,234,75, 0,26,197,62,94,252,219,203,117, 35,11,32,57,177,
33,88,237,149,56,87,174,20,125,136,171,168,68,175,74,165,71,134,139,
48,27,166, 77,146,158,231,83,111,229,122, 60,211,133,230,220,105,92,
41,55,46,245,40,244,102,143,54,65,25,63,161, 1,216,80,73,209,76,132,
187,208, 89, 18,169,200,196,135,130,116,188,159, 86,164,100,109,198,
173,186, 3,64,52,217,226,250,124,123,5,202,38,147,118,126,255,82,85,
212,207,206, 59,227, 47,16,58,17,182,189, 28,42,223,183,170,213,119,
248,152,2,44,154,163,70,221,153,101,155,167,43,172, 9,129,22,39,253,
19,98,108,110,79,113,224,232,178,185,112,104,218,246, 97,228,251,34,
242,193,238,210,144,12,191,179,162,241,81,51,145,235,249,14,239,107,
49,192,214, 31,181,199,106,157,184, 84,204,176,115,121,50,45,127, 4,
150,254,138,236,205, 93,222,114, 67,29,24, 72,243,141,128,195,78,66,
215,61,156,180
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
analogWrite(3,0);
analogWrite(5,0);
analogWrite(6,0);
x = float(millis())/200.0f;
o3 = fastFloor(128*generate(x + 19082) + 128);
o5 = fastFloor(128*generate(x + 5728) + 128);
o6 = fastFloor(128*generate(x) + 128);
analogWrite(3, o3);
analogWrite(5, o5);
analogWrite(6, o6);
delay(1);
float generate(float x)
int i0 = fastFloor(x);
int i1 = i0 + 1;
float x0 = x - i0;
float x1 = x0 - 1.0f;
float n0, n1;
float t0 = 1.0f - x0 * x0;
t0 *= t0;
n0 = t0 * t0 * grad(perm[i0 & 0xff], x0);
float t1 = 1.0f - x1 * x1;
t1 *= t1;
n1 = t1 * t1 * grad(perm[i1 & 0xff], x1);
// The maximum value of this noise is 8*(3/4)^4 = 2.53125
// A factor of 0.395 scales to fit exactly within [-1,1]
return 0.395f * (n0 + n1);
int fastFloor(float x)
return (x > 0) ? ((int)x) : (((int)x) - 1);
float grad(int hash, float x)
int h = hash & 15;
float grad = 1.0f + (h & 7); // Gradient value 1.0, 2.0, ..., 8.0
if ((h & 8) != 0) grad = -grad; // Set a random sign for the gradient
return (grad * x); // Multiply the gradient with the distance
