1st time coding. Error message interpretation
Hello Forum,
This is my first post.I have an Arduino Uno. I am trying to built and run "Spaceship Interface". I have error message reading " Board at COM1 is not available.
I copied this sketch from the examples-starter kit.
I may have something wrong with my wiring of the breadboard.
  Arduino Starter Kit example
  Project 2 - Spaceship Interface
  This sketch is written to accompany Project 2 in the Arduino Starter Kit
  Parts required:
  - one green LED
  - two red LEDs
  - pushbutton
  - 10 kilohm resistor
  - three 220 ohm resistors
  created 13 Sep 2012
  by Scott Fitzgerald
  http://www.arduino.cc/starterKit
  This example code is part of the public domain.
// Create a global variable to hold the state of the switch. This variable is
// persistent throughout the program. Whenever you refer to switchState, you’re
// talking about the number it holds
int switchstate = 0;
  // declare the LED pins as outputs
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // declare the switch pin as an input
  pinMode(2, INPUT);
  // read the value of the switch
  // digitalRead() checks to see if there is voltage on the pin or not
  switchstate = digitalRead(2);
  // if the button is not pressed turn on the green LED and off the red LEDs
  if (switchstate == LOW) {
    digitalWrite(3, HIGH); // turn the green LED on pin 3 on
    digitalWrite(4, LOW);  // turn the red LED on pin 4 off
    digitalWrite(5, LOW);  // turn the red LED on pin 5 off
  // this else is part of the above if() statement.
  // if the switch is not LOW (the button is pressed) turn off the green LED and
  // blink alternatively the red LEDs
  else {
    digitalWrite(3, LOW);  // turn the green LED on pin 3 off
    digitalWrite(5, HIGH); // turn the red LED on pin 5 on
    // wait for a quarter second before changing the light
    delay(250);
    digitalWrite(4, HIGH); // turn the red LED on pin 4 on
    delay(250);
Thanks,
DougV
New user
Select the port of your Arduino from the Tools > Port menu. If that menu is grayed out or the port of your Arduino board is not shown then one of the following may be the cause:
  • You may need to install the driver for the USB-serial chip on your Arduino. Determine which chip is used on your Arduino and install the driver.
  • You may be using a charge-only or defective USB cable. Test your cable on another device to confirm that it works for data.
  • Using a USB 3.0 port on your computer may cause problems. Try a USB 2.0 port or use a USB 2.0 hub plugged into your USB 3.0 port.
I'm new to this too, and remember that I had problems too. Have you checked that your computer recognized the COM port you're connecting your Arduino to? In my case, I had a bad cable that wasn't recognized by the computer.
Just tested the Blink sketch. Changed delay time and LED blinking sped up. So my computer is talking to the board. I will rebuild the breadboard again and try the Spaceship again.
Doug
Hello Forum,
Got the Spaceship Interface working ! For some reason the beginning book never told us to upload the new code.
One click and it is fine. I guess this is how one learns.
Doug
Good job! Enjoy.
