2.1GHz RF sig gen/control
Hello!
I want to make a small CW sig gen that transmits at 2.122 GHz, with quite accurate frequency. How would I go about that? I figured there might be a way to use some kind of oscillator chip, give it a high frequency input + another tuning signal from and arduino (and/or possibly provide test data patterns). The level accuracy isn't too important but would be nice to be controllable up to say 50 to a few hundred mW output?
Any ideas how feasible this is? Any pointers to similar projects or ideas on line? Or general guidance on what path I should go?
Cheers,
Phil.
What band is that frequency in? I don't recognise it.
European 3G (UMTS FDD band 1) downlink
Hi, I think you are looking for a DDS (Direct Digital Synthesizer) chip / Module. Fortunately today there are some at that frequency. See:
http://www.i0cg.com/ad9912___1_ghz_dds.htm
http://www.analog.com/static/imported-files/data_sheets/AD9956.pdf
Google "DDS 1.2 Ghz" etc... (Yes, meant 2.1 Ghz) What's a few cycles between friends?? :slight_smile:
Thanks. I assume you mean 2.1ghz not 1.2ghz (unless I'm missing something and I should use some kinda frequency doubler)
So the first step is to get a licence for the frequency?
Not if it's being used in a screened room! :slight_smile:
What the OP wishes to do is learn about "cell phone jammers".
Kinda! I want to make sure NOT to jam or degrade any of the UMTS band, except while stopping something connecting to a certain cell by jamming the downlink frequency it close range (within a few metres). Just a manually tunable fixed frequency narrowband signal would probably do, I'm just not sure how feasible that is.
Basically this principle/method works fine using a Rohde and Schwarz 20 GHz sig gen I have here, giving 15 dBm into a poorly tuned antenna. I can't have this here and use an expensive bit of test gear we need for other stuff, just for this though.
If I can make an oscillator that doesn't drift much and stays at 2122.4 MHz without varying out of it's 5 MHz channel bandwidth, then the simpler the better to be honest! All RF chips of this frequency seem to involve a certain amount of complexity and control for synthesis that I've found.
Piplodocus:
Well in the good old analog days if one wanted a simple stable RF signal at a specific frequency in the microwave band they would use a simple crystal oscillator (possible with a tunable 'padding cap' to be able to tweak the freq a little) followed by a harmonic generator stage (so called multiplier class C amp stages) followed by possible higher power amp stages and lastly a good bandpass filter for the final frequency desired. This was a common requirement for building a LO (local oscillator chain) for up or down conversions.
Lefty
I recently received Radcom the journal of the Radio Society of Great Britain for November.
There is a discussion within which describes the LMX2541, there are different versions dependant on frequency but the
specifications can be found here
Avnet: Quality Electronic Components & Services Search&inStock=&langId=-1&myCatalog=&npi=&proto=&regionalStock=&rohs=&storeId=500201&term=LMX2541&topSellers=&categoryLink=true
Mention is made also of a previous article in April 2012 which discussed the LMX2470. this requires a crystal oscillator at a stable frequency or a GPS source is also suggested. Tuning can be controlled by a PIC but I would say an Arduino would be more suitable.
These circuits are described as fractional N synthesisers which give virtually continuous tuning over a certain range.
Look them up and see if they can help you.
The article is written by Andy Talbot G4JNT with an interesting website at http://www.g4jnt.com/.
