2.2 TFT LCD Screen doesn't work with other components
Hey there,
I've been dealing with a pretty frustrating problem and couldn't find any answers on Google / This Forum / Adafruit's.
I've purchased the following 3 items for my project:
  1. NeoPixels 24 LED Ring - NeoPixel Ring - 24 x 5050 RGB LED with Integrated Drivers : ID 1586 : $16.95 : Adafruit Industries, Unique & fun DIY electronics and kits
  2. NeoPixels 8 LED Stick - NeoPixel Stick - 8 x 5050 RGB LED with Integrated Drivers : ID 1426 : $5.95 : Adafruit Industries, Unique & fun DIY electronics and kits
  3. 2.2 TFT LCD Screen - 2.2 18-bit color TFT LCD display with microSD card breakout [EYESPI Connector] : ID 1480 : $24.95 : Adafruit Industries, Unique & fun DIY electronics and kits
I am trying to make them three work together on the same Arduino Uno, in accordance with a Java Processing code which holds the logic of the whole project, using Serial communication.
My Processing code Serial.write()s a byte[] everytime it wants the Arduino to "bring something to life" through the LED and Screen components. The array at 0 holds an "opcode" to navigate inside the code, operating the different components.
The first two LED components are working relatively fine. The problem occurs when I try to synchronize the third component to work with them.
I used the only working thing to operate this third component (TFT Screen): ILI9340 Libraby. I used the graphicstest and spitftbitmap to check it works seperately and wired as needed. All works on its own.
However, as soon as I only use a single command to operate it, even in setup(), it messes everything up with the LED components.
Things I have tried:
  1. Running the Processing code without any screen-related-Arduino-code.
    LED components work, so I know the Processing code is not the problem.
  2. Running the screen-related-Arduino-code separately.
    The screen works, so it's not the problem nor it's connections.
  3. Running everything on a different Arduino Uno.
    Still doesn't work. The Arduino is not the problem.
  4. Commenting everything that Serial.print()s in the bmpdraw() method I am using in the code (see below), in case it messes up the Serial port.
    Nothing has changed (however if I run it separately it still works so I didn't comment anything I shouldn't have).
  5. Connecting the screen to 3.3V instead of 5V.
    The screen doesn't work with this voltage.
  6. Using this TFT Arduino library on the website: http://www.arduino.cc/en/Tutorial/TFTBitmapLogo.
    I figured maybe the ILI Library is the problem... However I couldn't use it. Even with the most simple code trying to paint the background red, the screen starts flickering:
#include <SD.h>
#include <SPI.h>
#include <TFT.h>
#define TFT_RST 9
#define TFT_DC 8
#define TFT_CS 10
#define SD_CS 4
TFT myScreen = TFT(TFT_CS, TFT_DC, TFT_RST);
  for (int p = 8; p < 14; p++) {
   pinMode(p, OUTPUT);
myScreen.begin();
myScreen.background(255, 0, 0);
PLEASE HELP!
How can I make it work?
P.S - if it matters at all, my final intention is to make the screen show bitmap photos.
Here's my full Arduino code:
#include <Adafruit_NeoPixel.h>  // Leds library
#include <avr/power.h>
#include <Adafruit_GFX.h>    // Core graphics library
#include "Adafruit_ILI9340.h" // Hardware-specific library
#include <SPI.h>
#include <SD.h>
#if defined(__SAM3X8E__)
    #undef __FlashStringHelper::F(string_literal)
    #define F(string_literal) string_literal
#endif
// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins.  For Arduino Uno,
// Duemilanove, etc., pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK.
#define TFT_RST 9
#define TFT_DC 8
#define TFT_CS 10
#define SD_CS 4
Adafruit_ILI9340 tft = Adafruit_ILI9340(TFT_CS, TFT_DC, TFT_RST);
// LED Variables
int r, g, b;
int location;
int amount;
byte byteValues[5];
// Set the pin to digital I/O
int stripPin = 2;
int ringPin = 3;
byte opCode;
Adafruit_NeoPixel ring = Adafruit_NeoPixel(60, ringPin, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, stripPin, NEO_GRB + NEO_KHZ800);
  // Sets screen
  tft.begin();
  SD.begin(SD_CS);
 // As soon as I use this, LED components stops working!
  // tft.fillScreen(ILI9340_BLACK);
  // bmpDraw("woof.bmp", 0, 0);
  // Sets LEDs
  pinMode(ringPin, OUTPUT);
  pinMode(stripPin, OUTPUT);
  ring.begin();
  strip.begin();
  // Initialize all pixels to 'off'
  ring.show();
  strip.show();
  //  // Turning off all leds
  //  for (int i = 0; i < 24; i++) {
  //    ring.setPixelColor(i, 0, 0, 0);
  while (Serial.available() > 4) {
    // Read values
    for (int i = 0; i < 5; i++) {
      byteValues[i] = Serial.read();
    opCode = byteValues[0];
    if (opCode == 10) {
      generateRing();
    else if (opCode == 20) {
      generateStrip();
    else if (opCode == 30) {
      generateScreen();
void generateRing() {
  r = byteValues[1];
  g = byteValues[2];
  b = byteValues[3];
  location = byteValues[4];
  ring.setBrightness(20);
  ring.setPixelColor(location, r, g, b);
  Serial.flush();
  ring.show();
void generateStrip() {
  for (int i = 0; i < 8; i++) {
    strip.setPixelColor(i, 0, 0, 0);
  r = byteValues[1];
  g = byteValues[2];
  b = byteValues[3];
  amount = byteValues[4];
  for (int i = 0; i < amount; i++) {
    strip.setBrightness(20);
    strip.setPixelColor(i, r, g, b);
  Serial.flush();
  strip.show();
void generateScreen() {
// Currently does nothing
Serial.flush();
Thanks in advance!
Probably not much help... but:
"The first two LED components are working relatively fine." This implies that there are some unresolved issues with the LEDcomponents?
It is good practice to initialise pins right at the start of the setup(), so I would move the lines:
// Sets LEDs
This will stop random noise pick up on these lines when the TFT is being exercised (which may be affecting the LED components).
