2.4" display does not update or turns white in project
Hello all together :slight_smile:
This is my first post in here and I just get up with a question...so I hope there is some help for me.
About me:
I like to work on DIY projects and this is where I get in contact with programming and especially programming the Arduino. Programming is not a passion for me just a way to solve a problem I am faced to. So I am one of those "copy and paste" programmers. I have some basic knowledge of programming (the 90's with Delphi and C...not much more), but I am not the god of programming my wife thinks I am :wink:
About the project:
I build myself a DIY Sous-Vide stick. Basically there is a heater (230V~) connected to an Arduino Uno via a SSR. A DS18B20 temperature probe is checking the water temperature the whole time. A 2.4 inch touch display allows me to set up the set-temperature of my water bath. On the other hand, the display has to show me the current temperature from the sensor.
The display works perfectly until I do anything with the temperature device. I can regulate the set-temperature by touch. But when the code for the sensor was inserted the following happened:
  • the current temperature in the display will not change (it starts with the right temperature but does not update it)
  • when I change the type of the temperature from int to float the display turns white after the first loop
I have a serial output listing the values at the same time, so I know it changes...
Might anybody be able to help?
Here's the code:
 *  ##### DIY Sous-Vide controller #####
 *  #####    © 2016 by Wotild      #####
// library SPFD5408
#include <SPFD5408_Adafruit_GFX.h>    // Core graphics library
#include <SPFD5408_Adafruit_TFTLCD.h> // Hardware-specific library
#include <SPFD5408_TouchScreen.h>     // Touch library
#include <OneWire.h>                  // onewire library
#include <DallasTemperature.h>        // DallasTemperature Library
//Define pin 10 for Onewire Temperaturesensor (DS18B20)
#define ONE_WIRE_BUS 10
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Calibrates value
#define SENSIBILITY 1000
#define MINPRESSURE 10
#define MAXPRESSURE 1000
#define TS_MINX 125
#define TS_MINY 85
#define TS_MAXX 965
#define TS_MAXY 905
//These are the pins for the shield!
#define YP A1
#define XM A2
#define YM 7
#define XP 6
// LCD Pin
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
// Init TouchScreen:
TouchScreen ts = TouchScreen(XP, YP, XM, YM, SENSIBILITY);
// Init LCD
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// Assign human-readable names to some common 16-bit color values:
#define WHITE   0x0000
#define YELLOW  0x001F
#define CYAN    0xF800
#define MAGENTA 0x07E0
#define RED     0x07FF
#define GREEN   0xF81F
#define BLUE    0xFFE0
#define BLACK   0xFFFF
#define GREY    0x7BEF
// Dimensions
uint16_t width = 0;
uint16_t height = 0;
// Pin for the SSR to regulate the heater
#define SSR 13
//#### SETUP ####
void setup(void)
  pinMode(SSR, OUTPUT);
  digitalWrite(SSR, LOW);
  // Start up the temp-sensor
  sensors.begin();
  // initialize the TFT
  tft.reset();
  tft.begin(0x9341);
  tft.setRotation(1); // Need for the Mega, please change for your choice or rotation initial
  tft.fillScreen(BLACK);
  width = tft.width() - 1; // do not know what this is for
  height = tft.height() - 1; // do not know what this is for
  //DrawGrid(25); // a grid to help the grafical design of the GUI
  StartScreen(); // draw the start screen
  waitOneTouch(); // wait for a user input to proceed
  MainScreen(); // draw the main screen
  Serial.begin(9600); // initialize the Serial port
//Variables
int SollTemp = 55;  // Set-temperature for the Sous-Vide
float IstTemp = 0;  // is-temperature in the bath
int XX = 170;       // some x-position on the TFT
TSPoint c;          // a point used in the loop
int x, y = 0;       // x and y coordinates to use
long Sekunden, Vergangen, alt = 0; // optional for a delay using the millis() command
//#### LOOP ####
  // print the values to verify what happens on the screen...
  Serial.print(IstTemp, 1);
  Serial.print("\t");
  Serial.print(SollTemp);
  Serial.print("\t");
  Serial.println(Vergangen);
  Sekunden = millis(); // set current "time" for the later delay
  tft.setRotation(1); // seems important, if this is not here the screen toggles the orientation...
  SollTemperatur(); // draw the set-temp screen
  Vergangen = Sekunden - alt; // set the time of the current loop
  if (Vergangen >= 2000) // if more than 2 seconds from the last update, update now
    IstTemperatur();
    alt = millis();
  c = ts.getPoint();    // get the touch point
  x = map(c.x, TS_MINX, TS_MAXX, 0, tft.width());
  y = map(c.y, TS_MINY, TS_MAXY, 0, tft.height());
  if (c.z > 0)    // if there is some pressure
    pinMode(XM, OUTPUT); //Pins configures again for TFT control...I do not know what this is for, but it does not work without
    pinMode(YP, OUTPUT);
    delay(200);   // delay to allow the finger to go away :)
    if ((x > XX) && (x < (XX + 63)) && (y > 10) && (y < 60))
      SollTemp += 10;
    if ((x > XX + 62) && (x < (XX + 62 + 63)) && (y > 10) && (y < 60))
      SollTemp += 1;
    if ((x > XX) && (x < (XX + 63)) && (y > 115) && (y < 115 + 50))
      SollTemp -= 10;
    if ((x > XX + 62) && (x < (XX + 62 + 63)) && (y > 115) && (y < 115 + 50))
      SollTemp -= 1;
  // set the SSR high or low depending on the temperature
  if (IstTemp >= SollTemp)
  if (IstTemp < SollTemp)
    digitalWrite(SSR, HIGH);
// draw a price-winning start-up screen
void StartScreen(void)
  tft.setCursor(20, 50);
  tft.setTextColor(WHITE);
  tft.setTextSize(5);
  tft.println("SousWiti");
  tft.setCursor(210, 160);
  tft.setTextColor(BLUE);
  tft.setTextSize(2);
  tft.println("TOUCH v2");
  tft.setCursor(5, 230);
  tft.setTextColor(YELLOW);
  tft.setTextSize(1);
  tft.println("C 2016 by Piti");
// draw the main screen with the buttons etc.
void MainScreen(void)
  //DrawGrid(25);
  //Buttons
  tft.fillRoundRect(XX, 10, 63, 50, 5, GREEN);
  tft.fillRoundRect(XX + 62, 10, 63, 50, 5, GREEN);
  tft.fillRoundRect(XX, 115, 63, 50, 5, RED);
  tft.fillRoundRect(XX + 62, 115, 63, 50, 5, RED);
  //Frame
  tft.drawRoundRect(XX, 10, 63, 50, 5, WHITE);
  tft.drawRoundRect(XX + 62, 10, 63, 50, 5, WHITE);
  tft.drawRoundRect(XX, 115, 63, 50, 5, WHITE);
  tft.drawRoundRect(XX + 62, 115, 63, 50, 5, WHITE);
  //bakcground
  tft.fillRect(XX, 50, 125, 75, BLACK);
  tft.drawRect(XX, 50, 125, 75, WHITE);
  tft.setTextSize(5);
  tft.setCursor(XX + 18, 13);
  tft.print("+");
  tft.setCursor(XX + 18 + 63, 13);
  tft.print("+");
  tft.setCursor(XX + 18, 127);
  tft.print("-");
  tft.setCursor(XX + 18 + 63, 127);
  tft.print("-");
// draw/print the set-temperature
void SollTemperatur(void)
  tft.setTextColor(WHITE, BLACK);
  tft.setCursor(10, 70);
  tft.setTextSize(5);
  tft.print("Soll");
  tft.setCursor(XX + 18, 59);
  tft.setTextSize(8);
  if (SollTemp > 90) SollTemp = 90;
  if (SollTemp < 20) SollTemp = 20;
  tft.print(SollTemp);
// get and draw/print the is-temperature
void IstTemperatur(void)
  tft.setCursor(10, 180);
  tft.setTextSize(5);
  tft.print("Ist ");
  tft.setCursor(XX + 8, 180);
  //request the temp from the sensor
  sensors.requestTemperatures();
  // store the current temp in the variable
  IstTemp = sensors.getTempCByIndex(0); // sensor.getTempC() does not work :(
  // if the set temperature is below the current temp, the number should be printed in alarming red color...
  if (IstTemp <= SollTemp)
    tft.setTextColor(RED, BLACK);
  // print the current temperature with one floating digit
  tft.println(IstTemp, 1);
// some helping funtcion I build to help to draw things
void DrawGrid(int Step)
  for (int i = Step; i <= width; i += Step) {
    tft.drawLine(i, 0, i, height, GREY);
    tft.drawLine(0, i, width, i, GREY);
// wait 1 touch to return the point
TSPoint waitOneTouch() {
  TSPoint p;
  do {
    p = ts.getPoint();
  } while (p.z < 500);
Thanks in advance!!!
I had a quick look at your code and cannot really help.
But I did notice you are using pins A1 and A2 for two different things - this might be creating a conflict !!!!
Best of luck
Hey cblx5, thanks for your input. It seemed to me strange, too, but the library example uses just this setup...so it seems so work. In deed it does.
Today I had a closer look to my script and I just tried something:
  c = ts.getPoint();
  if (c.z > 0)
I took the
and put it before the if-part.
Now everything works just fine...
This is the problem when using codes I do not understand what they are ment for...
Thanks for your help that far guys!!!
The TouchScreen.h library leaves YP, XM in INPUT mode after you call getPoint().
Fine for dedicated YP, XM pins. Not any good when they are shared with the TFT control signals.
I suggest that you place the pinMode() calls immediately after every getPoint() method.
Or you write a helper function that combines getPoint() and pinMode()s.
In an ideal world, the TouchScreen library would restore the mode. (if it knew it was "shared" e.g. an option flag setting)
Hey-ho. Just accept life for what it is.
David.
david_prentice:
That is what helped! Thanks David.
