2.4 Inch TFT with 4.2V Li-ion 1200 mah
Hello Friends ,
In my project Uno with a 2.8" TFT display (ili9341) is being used.Code & display working perfectly when its connected via computer USB.
Today tried with 4.2V Li-ion 1200 mah,Uno got powered up but TFT failed to display very dull Screen(Almost invisible).
(battery measured Voltage 4.19V)
Battery suppy Powered into Vin and GND.
Kindly suggest solution.
Thanks in advance.
Rezox
try this, not expensive... MT3608 2A DC-DC Step Up Power Apply Booster Power Module for Arduino
Thanks,
You mean 4.2V is not sufficient for TFT.
Vin is not suitable to power any TFT display. It has a weak LDO, that can only supply the UNO (plus some small IO output). LDO will further reduce the voltage.
Yes, use a step-up converter to 5V, and connect to 5V pin.
Alright Sir,I will apply your suggestion,Thanks
Thank You Sir
Thank you Sir
Thanks Mr.LFRED and Mr.ZinggJM.... My tft is working perfectly
