Your Uno does not have enough GPIO pins for a 16-bit parallel display.
An ESP32 does not have enough GPIO for 16-bit. It just has enough for 8-bit.
An ESP8266 does not have enough pins for ANY 8-bit parallel
It requires 3.3V logic. You should buy a 40-pin Adapter Shield for Mega2560. And the Mega2560 board to plug it into.
My Mega 2560 is already permanently occupied with another project; Can you direct me on which display to purchase at least 2.0' (possibly color a little expensive) to use with the board NANO or WEMOS?
Update! I found the exact picture of my model. Change something? Can I connect it to a Wemos D1 or a Lolin32 Wemos? How to connect? If I understand correctly it does not have an SPI interface, it is correct my guess?
An ESP32 does not have enough GPIO for 16-bit. It just has enough for 8-bit. An ESP8266 does not have enough pins for ANY 8-bit parallel
david_prentice:
The TTGO R32 board will work with that 8-bit parallel shield.
You have to make a minor hardware mod.
Then the shield will work with all controllers and MCUFRIEND_kbv and with TFT_eSPI libraries (popular controllers).
Bodmer's library can use that parallel shield but it also works with SPI controllers too.
and one V3 NodeMcu based on ESP8266 and CH340 NodeMCU
david_prentice:
Go on. Does no one know how to count any more?
Your D1 mini does not have many pins,
You can Google "ttgo r32". It should find a Uno format board available very cheap from Ebay.
You can Google Bodmer's library.. It even has photos of the hardware mod for the TTGO board.
You can hand-wire the display shield to your 30-pin modules. I do not advise it.
David.
Edit. If you have a problem with understanding the hardware mod photo / diagram, quote text and post a link to any document/webpage.
