I recently received a Due, a 2.4" TFT and a CTE TFT controller with on board SD.
I was able to use the UTF libraries to display things but I had trouble getting the SD to read using the SD libraries. After a bit of research on the shield I determined that jumper 8 needed to soldered closed allowing pin 53 to become the CS pin.
I failed using the ITDB02_tinyFAT16 and the demo example to display raw files because the library, as of this date, does not support the DUE. Having a bit of experience with Adafruit libraries and the SD library I opted to modify the bmpDraw routine from the Adafruit TFTLCD library example TFTBMP.
But: is there a way to speed this up? A 779x348p bmp takes about 22s to load (24 bit). Unfortunately bmps with a bit depth of 8 or 4 won`t be recognized
Hmmmm. Having experienced the same problems mboroff had, I took a different approach and modified UTFT_tinyFat to use SdFatLib. This allows us to use any size SD card, and folders.
Images need to be converted to .raw using Hennings converter which is included with UTFT library.
My version of UTFT_tinyFAT draws the following image sizes from Class 6 Samsung 32GB SD to 5" CPLD CTE TFT using CTE Shield and Arduino DUE.
Do you think it is worth making a github for this and/or contacting Henning with a view to introducing this to the UTFT suit of libraries such that SD cards >2GB and nested folders are allowed and functional with AVR or DUE Arduino?
Regards,
Graham
By the way, big THANKS for mention on your YOUTUBE clip!
If anyone interested, I ported the API driver HX8347A from Atmel ASF allowing Due via EBI/SMC to handle directly a 2.4 TFT LCD module drawing images from a SPI SD card breakout board. So far the time to load 320x240 bitmaps is 0.9 sec (it can be improved). I am working on the touchscreen feature.
Hi ghlawrence2000,
I found your modified tiny_UTFT and it works well, just what I was looking for.
Now I can view large images really fast. Thank you for this library
0.9sec for 320x240???? Are you sure that is what you mean?
My effort does a 320x240 raw image in 174ms......... = 0.174 sec!!
Regards,
Graham
Hello Graham,
I think 0.9 vs 0.174 secs is mostly because my slow SPI SDcard board, thus, and only for speed performance test purposes, I am going to use the internal 512KB FLASH of Due with my TFT library and draw a couple of 320x240 bitmaps to measure the refresh rate. Now, I am aloso thinking to use a Winbond W25QXX flash memory with Due to show short video clips. Regards,
I have a dozen of the winbond 25Q128FVSG, that I intend to create my own font/icon ic similar to the CTE display and shield, but I have not got far with it yet as a result of my due falling apart and other things but I would be VERY interested to see how far you get with video!! That would be amazing if you can pull off SEVERAL frames per second!!
