2.4" TFT LCD display white screen
I have arduino mega with 2.4" TFT LCD that displays white screen. I run almost all graphic-tests on it but they didn't work.
that means it shows white.
i read the lcd reg. but it doesn't work .
could you please help me in this way ?
The monitor result of the graphic test is below block
TFT
he breakout board, it should NOT be #defined!
Also if using the breakout, double-check that all wiring
matches the tutorial.
TFT LCD test
Using Adafruit 2.8" TFT Breakout Board Pinout
TFT size is 240x320
Unknown LCD driver chip: 3245
If using the Adafruit 2.8" TFT Arduino shield, the line:
  #define USE_ADAFRUIT_SHIELD_PINOUT
should appear in the library header (Adafruit_TFT.h).
If using the breakout board, it should NOT be #defined!
And the result of register_id code is this block
reg(0x0000) 45 32	ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 00 00 00	Manufacturer ID
reg(0x0009) 00 00 00 00 00	Status Register
reg(0x0061) 00 00	RDID1 HX8347-G
reg(0x0062) 00 00	RDID2 HX8347-G
reg(0x0063) 00 00	RDID3 HX8347-G
reg(0x0064) 00 00	RDID1 HX8347-A
reg(0x0065) 00 00	RDID2 HX8347-A
reg(0x0066) 00 00	RDID3 HX8347-A
reg(0x0067) 00 00	RDID Himax HX8347-A
reg(0x0070) 00 00	Panel Himax HX8347-A
reg(0x00A1) 00 00 00 00 00	RD_DDB SSD1963
reg(0x00B0) 00 00	RGB Interface Signal Control
reg(0x00B4) 00 00	Inversion Control
reg(0x00B6) 00 00 00 00 00	Display Control
reg(0x00B7) 00 00	Entry Mode Set
reg(0x00BF) 00 01 00 01 00 01	ILI9481, HX8357-B
reg(0x00C0) 00 00 00 00 00 00	Panel Control
reg(0x00CC) 01 01	Panel Control
reg(0x00D0) 00 00 00	Power Control
reg(0x00D2) 00 00 00 00 00	NVM Read
reg(0x00D3) 00 00 00 00	ILI9341, ILI9488
reg(0x00DA) 00 00	RDID1
reg(0x00DB) 00 00	RDID2
reg(0x00DC) 00 00	RDID3
reg(0x00EF) 00 00 00 00 00 00	ILI9327
reg(0x00F2) 00 00 00 00 00 00 00 00 00 00 00 00	Adjust Control 2
reg(0x00F6) 00 00 00 00	Interface Control
You should probably ask the Moderator to move this to 'Displays'.
