Hello,
I have a 2.4 tft with spfd controller.I download the UTFT library.I connected everything and check everything a lot of times.
My problem is that the sketch I upload works fine,I can see it running on tft but the screen is always full of colored lines.
I upload some very simple code but everything I do the problem is the same.You can see the pictures.
I check the regulator on tft module and works fine 3.37v and 4.98v.I checked all cables and everything is ok!!!
http://www.ebay.com/itm/111263654864?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://s1371.photobucket.com/user/trikoupos/media/DSCN0638_zps1aafb5f6.jpg.html
this is the code:
// UTFT_Demo_320x240 (C)2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of how to use most of the functions
// of the library with a supported display modules.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t SmallFont;
// Uncomment the next line for Arduino 2009/Uno
UTFT myGLCD(SPFD5408A,A2,A1,A3,A4); // Remember to change the model parameter to suit your display module!
// Uncomment the next line for Arduino Mega
//UTFT myGLCD(ITDB32S,38,39,40,41); // Remember to change the model parameter to suit your display module!
randomSeed(analogRead(0));
// Setup the LCD
pinMode(A0,OUTPUT); // for the UNO_SHIELD_1IN1
digitalWrite(A0,HIGH); // the RD pin must be set high
myGLCD.InitLCD();
myGLCD.setFont(SmallFont);
int buf[318];
int x, x2;
int y, y2;
int r;
// Clear the screen and draw the frame
myGLCD.clrScr();
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, 319, 13);
myGLCD.setColor(64, 64, 64);
myGLCD.fillRect(0, 226, 319, 239);
myGLCD.setColor(255, 255, 255);
myGLCD.setBackColor(255, 0, 0);
myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
myGLCD.setBackColor(64, 64, 64);
myGLCD.setColor(255,255,0);
myGLCD.print(“http://electronics.henningkarlsen.com”, CENTER, 227);
myGLCD.setColor(0, 0, 255);
myGLCD.drawRect(0, 14, 319, 225);
// Draw crosshairs
myGLCD.setBackColor(0, 0, 0);
myGLCD.drawLine(159, 15, 159, 224);
myGLCD.drawLine(1, 119, 318, 119);
for (int i=9; i<310; i+=10)
myGLCD.drawLine(i, 117, i, 121);
for (int i=19; i<220; i+=10)
myGLCD.drawLine(157, i, 161, i);
// Draw sin-, cos- and tan-lines
myGLCD.setColor(0,255,255);
myGLCD.print(“Sin”, 5, 15);
for (int i=1; i<318; i++)
myGLCD.drawPixel(i,119+(sin(((i*1.13)*3.14)/180)*95));
myGLCD.setColor(255,0,0);
myGLCD.print(“Cos”, 5, 27);
myGLCD.drawPixel(i,119+(cos(((i*1.13)*3.14)/180)*95));
myGLCD.print(“Tan”, 5, 39);
myGLCD.drawPixel(i,119+(tan(((i*1.13)*3.14)/180)));
delay(2000);
myGLCD.setColor(0,0,0);
myGLCD.fillRect(1,15,318,224);
// Draw a moving sinewave
x=1;
for (int i=1; i<(31820); i++)
x++;
if (x==319)
x=1;
if (i>319)
if ((x==159)||(buf[x-1]==119))
myGLCD.setColor(0,0,255);
myGLCD.drawPixel(x,buf[x-1]);
y=119+(sin(((i1.1)3.14)/180)(90-(i / 100)));
myGLCD.drawPixel(x,y);
buf[x-1]=y;
delay(2000);
// Draw some filled rectangles
for (int i=1; i<6; i++)
switch (i)
case 1:
myGLCD.setColor(255,0,255);
case 2:
case 3:
myGLCD.setColor(0,255,0);
case 4:
case 5:
myGLCD.fillRect(70+(i20), 30+(i20), 130+(i20), 90+(i20));
delay(2000);
// Draw some filled, rounded rectangles
switch (i)
case 1:
case 2:
case 3:
case 4:
case 5:
myGLCD.fillRoundRect(190-(i20), 30+(i20), 250-(i20), 90+(i20));
delay(2000);
// Draw some filled circles
switch (i)
case 1:
case 2:
case 3:
case 4:
case 5:
myGLCD.fillCircle(100+(i20),60+(i20), 30);
delay(2000);
// Draw some lines in a pattern
myGLCD.setColor (255,0,0);
for (int i=15; i<224; i+=5)
myGLCD.drawLine(1, i, (i1.44)-10, 224);
for (int i=224; i>15; i-=5)
myGLCD.drawLine(318, i, (i1.44)-11, 15);
myGLCD.setColor (0,255,255);
myGLCD.drawLine(1, i, 331-(i1.44), 15);
myGLCD.drawLine(318, i, 330-(i1.44), 224);
delay(2000);
// Draw some random circles
for (int i=0; i<100; i++)
myGLCD.setColor(random(255), random(255), random(255));
x=32+random(256);
y=45+random(146);
r=random(30);
myGLCD.drawCircle(x, y, r);
delay(2000);
// Draw some random rectangles
x=2+random(316);
y=16+random(207);
x2=2+random(316);
y2=16+random(207);
myGLCD.drawRect(x, y, x2, y2);
delay(2000);
// Draw some random rounded rectangles
x=2+random(316);
y=16+random(207);
x2=2+random(316);
y2=16+random(207);
myGLCD.drawRoundRect(x, y, x2, y2);
delay(2000);
x=2+random(316);
y=16+random(209);
x2=2+random(316);
y2=16+random(209);
myGLCD.drawLine(x, y, x2, y2);
delay(2000);
for (int i=0; i<10000; i++)
myGLCD.drawPixel(2+random(316), 16+random(209));
delay(2000);
myGLCD.fillScr(0, 0, 255);
myGLCD.fillRoundRect(80, 70, 239, 169);
myGLCD.print(“That’s it!”, CENTER, 93);
myGLCD.print(“Restarting in a”, CENTER, 119);
myGLCD.print(“few seconds…”, CENTER, 132);
myGLCD.setColor(0, 255, 0);
myGLCD.setBackColor(0, 0, 255);
myGLCD.print(“Runtime: (msecs)”, CENTER, 210);
myGLCD.printNumI(millis(), CENTER, 225);
delay (10000);
Can someone tell me whats going wrong??
Thanks in advance…
