Maybe I am just being stupid due to lack of sleep or something else. But I am not able to get most of the programs to compile, The compiler is giving several errors.
I have already tested the programme on an Arduino UNO and MEGA and it works there. Only the Arduino UNO and MEGA work with an Atmel microcontroller and the GIGA with an STM microcontroller.
Can you please help me?
I upload my error messages.
#define CS_ACTIVE PIN_LOW(CS_PORT, CS_PIN) ^
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:37: note: in definition of macro 'CS_ACTIVE'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:37: note: suggested alternative: 'SPI1'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:20: error: 'PIN_LOW' was not declared in this scope
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:20: note: in definition of macro 'CS_ACTIVE'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:20: note: suggested alternative: 'PIN_LED'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1222:28: error: 'CD_PORT' was not declared in this scope
#define CD_COMMAND PIN_LOW(CD_PORT, CD_PIN)
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1222:28: note: in definition of macro 'CD_COMMAND'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:122:5: note: in expansion of macro 'WriteCmd'
WriteCmd(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1222:28: note: suggested alternative: 'STM_PORT'
WriteCmd(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1222:37: error: 'CD_PIN' was not declared in this scope
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1222:37: note: in definition of macro 'CD_COMMAND'
WriteCmd(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1222:37: note: suggested alternative: 'STM_PIN'
WriteCmd(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1240:36: error: 'write16' was not declared in this scope
#define WriteCmd(x) { CD_COMMAND; write16(x); CD_DATA; }
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1240:36: note: in definition of macro 'WriteCmd'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1240:36: note: suggested alternative: 'write24'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1223:20: error: 'PIN_HIGH' was not declared in this scope
#define CD_DATA PIN_HIGH(CD_PORT, CD_PIN)
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1223:20: note: in definition of macro 'CD_DATA'
WriteCmd(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1223:20: note: suggested alternative: 'HIGH'
WriteCmd(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:125:9: error: 'write8' was not declared in this scope
write8(u8);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:125:9: note: suggested alternative: 'write'
write8(u8);
write
In file included from c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:38:0:
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:128:13: note: in expansion of macro 'WriteCmd'
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1226:20: error: 'PIN_HIGH' was not declared in this scope
#define CS_IDLE PIN_HIGH(CS_PORT, CS_PIN)
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1226:20: note: in definition of macro 'CS_IDLE'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1226:20: note: suggested alternative: 'HIGH'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'uint16_t read16bits()':
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:154:5: error: 'READ_8' was not declared in this scope
READ_8(ret);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:154:5: note: suggested alternative: 'PE_8'
READ_8(ret);
PE_8
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'uint16_t MCUFRIEND_kbv::readReg(uint16_t, int8_t)':
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:28: error: 'CS_PORT' was not declared in this scope
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:28: note: in definition of macro 'CS_ACTIVE'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:28: note: suggested alternative: 'STM_PORT'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1225:37: error: 'CS_PIN' was not declared in this scope
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:169:5: note: in expansion of macro 'WriteCmd'
WriteCmd(reg);
WriteCmd(reg);
WriteCmd(reg);
WriteCmd(reg);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1240:36: note: suggested alternative: 'write'
WriteCmd(reg);
WriteCmd(reg);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:170:5: error: 'setReadDir' was not declared in this scope
setReadDir();
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:170:5: note: suggested alternative: 'seekdir'
setReadDir();
seekdir
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:29: error: 'RD_PORT' was not declared in this scope
#define RD_IDLE PIN_HIGH(RD_PORT, RD_PIN)
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:29: note: in definition of macro 'RD_IDLE'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:29: note: suggested alternative: 'STM_PORT'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:38: error: 'RD_PIN' was not declared in this scope
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:38: note: in definition of macro 'RD_IDLE'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:38: note: suggested alternative: 'STM_PIN'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:20: error: 'PIN_HIGH' was not declared in this scope
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:20: note: in definition of macro 'RD_IDLE'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:20: note: suggested alternative: 'HIGH'
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:176:5: error: 'setWriteDir' was not declared in this scope
setWriteDir();
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:176:5: note: suggested alternative: 'setWriteError'
setWriteDir();
setWriteError
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'int16_t MCUFRIEND_kbv::readGRAM(int16_t, int16_t, uint16_t*, int16_t, int16_t)':
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:311:9: note: in expansion of macro 'WriteCmd'
WriteCmd(_MR);
WriteCmd(_MR);
WriteCmd(_MR);
WriteCmd(_MR);
WriteCmd(_MR);
WriteCmd(_MR);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:312:9: error: 'setReadDir' was not declared in this scope
setReadDir();
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:312:9: note: suggested alternative: 'seekdir'
setReadDir();
seekdir
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:316:13: error: 'READ_8' was not declared in this scope
READ_8(r);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:316:13: note: suggested alternative: 'PE_8'
READ_8(r);
PE_8
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:318:13: error: 'READ_16' was not declared in this scope
READ_16(dummy);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:318:13: note: suggested alternative: 'READ_REG'
READ_16(dummy);
READ_REG
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:320:26: error: 'READ_8' was not declared in this scope
if (_lcd_ID == 0x1511) READ_8(r); //extra dummy for R61511
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:320:26: note: suggested alternative: 'PE_8'
PE_8
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:323:17: error: 'READ_8' was not declared in this scope
READ_8(r);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:323:17: note: suggested alternative: 'PE_8'
READ_8(r);
PE_8
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:331:17: error: 'READ_16' was not declared in this scope
READ_16(ret);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:331:17: note: suggested alternative: 'READ_REG'
READ_16(ret);
READ_REG
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:352:9: error: 'setWriteDir' was not declared in this scope
setWriteDir();
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:352:9: note: suggested alternative: 'setWriteError'
setWriteDir();
setWriteError
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::drawPixel(int16_t, int16_t, uint16_t)':
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:541:30: note: in expansion of macro 'WriteCmd'
if (is9797) { CS_ACTIVE; WriteCmd(_MW); write24(color); CS_IDLE;} else
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::fillRect(int16_t, int16_t, int16_t, int16_t, uint16_t)':
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:616:5: note: in expansion of macro 'WriteCmd'
WriteCmd(_MW);
WriteCmd(_MW);
WriteCmd(_MW);
WriteCmd(_MW);
WriteCmd(_MW);
WriteCmd(_MW);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:659:18: error: 'write8' was not declared in this scope
write8(r);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:659:18: note: suggested alternative: 'write'
write8(r);
write
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:666:13: error: 'write8' was not declared in this scope
write8(hi);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:666:13: note: suggested alternative: 'write'
write8(hi);
write
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void pushColors_any(uint16_t, uint8_t*, int16_t, bool, uint8_t)':
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:684:9: note: in expansion of macro 'WriteCmd'
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:691:13: error: 'write16' was not declared in this scope
write16(color);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:691:13: note: suggested alternative: 'write24'
write16(color);
write24
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:708:9: error: 'write16' was not declared in this scope
write16(color);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:708:9: note: suggested alternative: 'write24'
write16(color);
write24
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void init_table(const void*, int16_t)':
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:877:13: error: 'write8' was not declared in this scope
write8(cmd);
c:\Users\name\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:877:13: note: suggested alternative: 'write'
write8(cmd);
write
exit status 1
Compilation error: exit status 1
