2 7 segment display counter with 1 pushbutton
Hello all,
im trying to make a 00-99 counter that increments by 2 for a basketball score keeper project. The problem is: i get the Arduino uno to read the push button and set the score as 2 then display two on the LEDs, but when i push it again it does not jump from 2 to 4. not sure if it isnt looping or if its just getting stuck on 2? here is the loop and the commands to put it on the LED.
  buttonVal = digitalRead(button); //checks button
  if (buttonVal == HIGH){ //if button is pressed
    score = score + 2; //adds 2 to the score
    counter();
void counter(){
  if(score == 2){
    offf();
    two();
  if(score == 4){
    offf();
    four();
What does offf() do?
What does two() do?
What does four() do?
Post ALL your code, not just a snippet.
And try balancing your curly braces...you haven't closed loop() before defining counter().
Sorry,
the off() two() etc. sets the leds on. example:
void off(){ //turns off all lights
  digitalWrite(G, HIGH);
  digitalWrite(F, HIGH);
  digitalWrite(A, HIGH);
  digitalWrite(B, HIGH);
  digitalWrite(E, HIGH);
  digitalWrite(D, HIGH);
  digitalWrite(C, HIGH);
  delay(10);
and the curly brackets are correct on my actual code.. copy and paste error here
I guess you missed the "ALL your code" portion of the response...
You don't want to increment it when the button is HIGH, because it will likely be HIGH for thousands of iterations before the button is released. Look at the StateChangeDetection example.
const int A = 0;
const int B = 1;
const int C = 2;
const int D = 3;
const int E = 4;
const int F = 5;
const int G = 6;
const int AA = 7;
const int BB = 8;
const int CC = 9;
const int DD = 10;
const int EE = 11;
const int FF = 12;
const int GG = 13;
const int button = A1; //creates aninstance of button
int score;
int buttonVal = 0; //holds the buttons current value
int buttonOldVal = 0; //holds the buttons previous value
  digitalWrite(F, LOW);
  digitalWrite(A, LOW);
  digitalWrite(B, LOW);
  digitalWrite(E, LOW);
  digitalWrite(D, LOW);
  digitalWrite(C, LOW);
  digitalWrite(GG, HIGH);
  digitalWrite(FF, LOW);
  digitalWrite(AA, LOW);
  digitalWrite(BB, LOW);
  digitalWrite(EE, LOW);
  digitalWrite(DD, LOW);
  digitalWrite(CC, LOW);
  pinMode(0,OUTPUT);
  pinMode(1,OUTPUT);
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(13,OUTPUT);
  pinMode(A1,INPUT);
void loop(){
    score = score + 2;
void counter(){
if(score == 2){
    offf();
    two();
  if(score == 4){
    offf();
    four();
  if(score == 6){
    zero();
    six();
  delay(10);
void offf(){ //turns off all lights
  digitalWrite(FF, HIGH);
  digitalWrite(AA, HIGH);
  digitalWrite(BB, HIGH);
  digitalWrite(EE, HIGH);
  digitalWrite(DD, HIGH);
  digitalWrite(CC, HIGH);
  delay(10);
void zero(){ //shows the number zero
  delay(10);
void zeroo(){ //shows the number zero
  delay(10);
void one(){ //shows the number one
  delay(10);
void onee(){ //shows the number one
  delay(10);
void two(){ //shows the number two
  digitalWrite(G, LOW);
  delay(10);
void twoo(){ //shows the number two
  digitalWrite(GG, LOW);
  delay(10);
void three(){ //shows the number three
  delay(10);
void threee(){ //shows the number three
  delay(10);
void fourr(){ //shows the number four
  delay(10);
void four(){ //shows the number four
  delay(10);
void five(){ //shows the number five
  delay(10);
void fivee(){ //shows the number five
  delay(10);
void six(){ //shows the number six
  delay(10);
void sixx(){ //shows the number six
  delay(10);
void seven(){ //shows the number seven
  delay(10);
void sevenn(){ //shows the number seven
  delay(10);
void eight(){ //shows the number eight
  delay(10);
void eightt(){ //shows the number eight
  delay(10);
void nine(){ //shows the number nine
  delay(10);
void ninee(){ //shows the number nine
  delay(10);
all of my code
void loop(){
    score = score + 2;
counter() is never called, so I don't see how you can expect your display to update...
it was in there.. i been changing stuff alot and forgot to retype it in there..
if i dont want it to be high what would u recomend it?
Silveira89:
Take the joint away?
What don't you want to be high? Try not to use pronouns like "it".
how would i get it to increment without reading when the button is high? sorry at work, multitasking isnt my thing appearently
Silveira89:
Look at the last sentence in the post you just quoted.
