2.8 LCD TFT ILI9341 Touch is mirrored.
Hey eveyone, having an issue with my touchscreen. The touch seems to be "mirrored" where x and y aren't moving correctly. I have tried to switch the X and Y around but this doesn't solve anything. It makes it a little better (X will move in the right direction but Y is still not working right).
Up = Right
Down = Left
Right = Down
Left = Up
I'm not sure what is causing this but I'll leave the code I'm using and the libraries.
#include <Adafruit_GFX.h>
#include <Adafruit_TFTLCD.h>
#include <stdint.h>
#include "TouchScreen.h"
//Graphics Definitions
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
//TouchScreen definitions
#define YP A2
#define XM A3
#define YM 8
#define XP 9
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
//Color Definitions
#define  BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x0FF0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define DEBUG
void setup(void) {
  tft.reset();
  uint16_t identifier = tft.readID();
  tft.setCursor(0, 0);
  tft.begin(identifier);
  tft.fillScreen(BLACK);
  digitalWrite(13, HIGH);
  TSPoint p = ts.getPoint();
  digitalWrite(13, LOW);
  //pinMode(XP, OUTPUT);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  //pinMode(YM, OUTPUT);
    if (p.z > ts.pressureThreshhold) {
      Serial.print(p.x);
      Serial.print(" x ");
      Serial.println(p.y);
      tft.drawPixel((p.x - 200)/2, (p.y - 204)/2, GREEN);
[Edit] This is the LCD I have. I'm using this on an Arduino Uno.
Touch_Screen_Driver-master.zip (6.12 KB)
I'm just guessing, but I think you need to add....
#include "Adafruit_ILI9341.h"
unsigned int rotation=2;
tft.setRotation(rotation);
I had similar digitizer problem, but using a different ILI9341 library.
It's not the trouble, but your pinModes
should be in setup ( ), not in loop ( ).
If you try Borland's idea, just add
unsigned int rotation=2; // with other declarations, before setup ( )
and
tft.setRotation(rotation); // in setup ( )
without the library include
borland:
Hmm tried this and the results are still the same. Not changing the directions.
Sorry about that.
Have you tried swapping the XM, YM and XP, YP pin pairs assignments in your code with the #define statements? You could also swap the hardware wires, but easier to swap with software.
borland:
Sorry about that.
I have tried that but I will try it again. Hopefully it will produce some different results. And don't be sorry lol you tried to help and that's all I can ask for at the moment.
I was looking at the AdaFruit ILI9341 library on GitHub. They have two touchpaint code examples, one for the shield LCD and the other for a breakout board LCD. A note in the breakout example says it's not for the shield LCD. It looks like your code is similar to the breakout example.
Have you tried loading those library examples?
borland:
I have tried both of them and if I remember correctly there was an error when compiling the code for the sheild. I can not remember what the error was but I'll look at it in a moment and post the results.
Build options changed, rebuilding all
tftpaint_shield:14: error: #error "This sketch is intended for use with the TFT LCD Shield. Make sure that USE_ADAFRUIT_SHIELD_PINOUT is #defined in the Adafruit_TFTLCD.h library file."
Is the error I am getting.
That ILI9341 library must not be the latest. The GitHub ILI9341 library does not contain a file by that name (tftpaint_shield). It contains a example file named: touchpaint.ino.
borland:
GitHub - adafruit/Adafruit_ILI9341: Library for Adafruit ILI9341 displays
I tried the library and I was missing STMPE610 so I downloaded that library as well. I tried to set it up but all I was getting was a white screen. I actually have the paint from the old one slightly working. Up and Down are now working fine but left and right is mirrored. This is a step forward but I'm not sure how to fix it completely. Again though, thank you for all your help so far.
Here is the code I am using where only left and right is wrong.
// Paint example specifically for the TFTLCD breakout board.
// If using the Arduino shield, use the tftpaint_shield.pde sketch instead!
// DOES NOT CURRENTLY WORK ON ARDUINO LEONARDO
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <TouchScreen.h>
#if defined(__SAM3X8E__)
    #undef __FlashStringHelper::F(string_literal)
    #define F(string_literal) string_literal
#endif
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
//   D0 connects to digital pin 8  (Notice these are
//   D1 connects to digital pin 9   NOT in order!)
//   D2 connects to digital pin 2
//   D3 connects to digital pin 3
//   D4 connects to digital pin 4
//   D5 connects to digital pin 5
//   D6 connects to digital pin 6
//   D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
//   D0 connects to digital pin 22
//   D1 connects to digital pin 23
//   D2 connects to digital pin 24
//   D3 connects to digital pin 25
//   D4 connects to digital pin 26
//   D5 connects to digital pin 27
//   D6 connects to digital pin 28
//   D7 connects to digital pin 29
// For the Arduino Due, use digital pins 33 through 40
//   D0 connects to digital pin 33
//   D1 connects to digital pin 34
//   D2 connects to digital pin 35
//   D3 connects to digital pin 36
//   D4 connects to digital pin 37
//   D5 connects to digital pin 38
//   D6 connects to digital pin 39
//   D7 connects to digital pin 40
#define YP A3  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 9   // can be a digital pin
#define XP 8   // can be a digital pin
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
// Assign human-readable names to some common 16-bit color values:
#define	BLUE    0x001F
#define	RED     0xF800
#define	GREEN   0x07E0
#define CYAN    0x07FF
#define BOXSIZE 40
#define PENRADIUS 3
int oldcolor, currentcolor;
void setup(void) {
  Serial.println(F("Paint!"));
  tft.reset();
    if(identifier == 0x9325) {
    Serial.println(F("Found ILI9325 LCD driver"));
  } else if(identifier == 0x9327) {
    Serial.println(F("Found ILI9327 LCD driver"));
  } else if(identifier == 0x9328) {
    Serial.println(F("Found ILI9328 LCD driver"));
  } else if(identifier == 0x7575) {
    Serial.println(F("Found HX8347G LCD driver"));
  } else if(identifier == 0x9341) {
    Serial.println(F("Found ILI9341 LCD driver"));
  } else if(identifier == 0x8357) {
    Serial.println(F("Found HX8357D LCD driver"));
  } else if(identifier == 0x0154) {
    Serial.println(F("Found S6D0154 LCD driver"));
    Serial.print(F("Unknown LCD driver chip: "));
    Serial.println(identifier, HEX);
    Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
    Serial.println(F("  #define USE_ADAFRUIT_SHIELD_PINOUT"));
    Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
    Serial.println(F("If using the breakout board, it should NOT be #defined!"));
    Serial.println(F("Also if using the breakout, double-check that all wiring"));
    Serial.println(F("matches the tutorial."));
    return;
  tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
  tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
  tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN);
  tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN);
  tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE);
  tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA);
  // tft.fillRect(BOXSIZE*6, 0, BOXSIZE, BOXSIZE, WHITE);
  tft.drawRect(0, 0, BOXSIZE, BOXSIZE, WHITE);
  currentcolor = RED;
  pinMode(13, OUTPUT);
#define MINPRESSURE 10
#define MAXPRESSURE 1000
  // if sharing pins, you'll need to fix the directions of the touchscreen pins
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    Serial.print("X = "); Serial.print(p.x);
    Serial.print("\tY = "); Serial.print(p.y);
    Serial.print("\tPressure = "); Serial.println(p.z);
    if (p.y < (TS_MINY-5)) {
      Serial.println("erase");
      // press the bottom of the screen to erase
      tft.fillRect(0, BOXSIZE, tft.width(), tft.height()-BOXSIZE, BLACK);
    // scale from 0->1023 to tft.width
    p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
    p.y = map(p.y, TS_MINY, TS_MAXY, tft.height()-BOXSIZE*2, 0);
    Serial.print("("); Serial.print(p.x);
    Serial.print(", "); Serial.print(p.y);
    Serial.println(")");
    if (p.y < BOXSIZE) {
       oldcolor = currentcolor;
       if (p.x < BOXSIZE) {
         currentcolor = RED;
       } else if (p.x < BOXSIZE*2) {
         currentcolor = YELLOW;
         tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, WHITE);
       } else if (p.x < BOXSIZE*3) {
         currentcolor = GREEN;
         tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, WHITE);
       } else if (p.x < BOXSIZE*4) {
         currentcolor = CYAN;
         tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, WHITE);
       } else if (p.x < BOXSIZE*5) {
         currentcolor = BLUE;
         tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, WHITE);
       } else if (p.x < BOXSIZE*6) {
         currentcolor = MAGENTA;
         tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, WHITE);
       if (oldcolor != currentcolor) {
          if (oldcolor == RED) tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
          if (oldcolor == YELLOW) tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
          if (oldcolor == GREEN) tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN);
          if (oldcolor == CYAN) tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN);
          if (oldcolor == BLUE) tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE);
          if (oldcolor == MAGENTA) tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA);
    if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
      tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
Update: I FIXED IT!!! Haha I'll post the code below explaining what I did.
#endif
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define	BLUE    0x001F
#define	RED     0xF800
#define CYAN    0x07FF
#define BOXSIZE 40
#define PENRADIUS 3
void setup(void) {
  tft.reset();
    return;
  currentcolor = RED;
    p.y = map(p.y, TS_MAXY, TS_MINY, tft.height()-BOXSIZE*2, 0); //Here I changed the values of the MAXY and MINY around.
         currentcolor = RED;
All I had to do was change the MAXY and MINY values around in the map and it began to work in the right directions!
Does that correction make your original sketch work?
Glad you got it running.
Next time be careful when you buy modules from sellers that know very little of what they are selling. It's important to get component technical datasheets and hopefully useful software library.
