SOLVED - this weird behavior was a symptom of not having the two 470ohm RS485 bus resistors in place (from A to 5V and from B to GND). Mistakenly thought they were part of the RS485 board itself.
Hi. I have 2 Arduino UNO R3s wired up for RS485 and using the SimpleModBus protocol (SimpleModbusMasterV2rev2 and SimpleModbusSlaveV10). Each Arduino has a pot on A0 and the intent is to use the pot to control the LED blink rate on the other Arduino's board over the RS485/SimpleModBus link.
Two packets are defined for the Master - one for function 3 READ_HOLDING_REGISTERS and one for function 16 PRESET_MULTIPLE_REGISTERS.
Function 3 is working fine - the slave is getting the function 3 packet, processing, returning the slave pot value from its register SLAVE_POT, and master is controlling its LED from that value just as designed.
However, the function 16 is not working at all. The data is always received by the slave as 0. I think I've ruled out a problem associated with the master_regs[MASTER_POT] = map(potValue, 380, 630, 0, 1000); line - I can hardcode master_regs[MASTER_POT] to a nonzero value like 500 and the data is still received as 0 by the slave. I've also looked at the data stream in the serial monitor and the function 16 data is not changing when moving the master pot around. (For the function 3 I can see the values moving as I play with the slave pot.) So it seems like an issue with the assembly of the packet but I can't figure it out. I'm hoping someone here can spot the issue.
Thanks
Master:
#include <SimpleModbusMaster.h>
#define baud 9600
#define timeout 1000
#define polling 200
#define retry_count 10
#define TxEnablePin 2
enum
PACKET1,
PACKET2,
TOTAL_NO_OF_PACKETS
Packet packets[TOTAL_NO_OF_PACKETS];
enum
MASTER_POT,
SLAVE_POT,
NO_OF_REGS
unsigned int master_regs[NO_OF_REGS];
unsigned int potPin = A0;
unsigned int ledPin = 13;
unsigned int potValue = 0;
unsigned int ledDelay = 0;
unsigned int currentMillis;
unsigned int previousMillis;
unsigned int slave_pot;
pinMode(ledPin,OUTPUT);
digitalWrite(ledPin,LOW);
previousMillis = millis();
//Packet1: slave 1, read, from slave register SLAVE_POT, length 1, put into master register SLAVE_POT
modbus_construct(&packets[PACKET1], 1, READ_HOLDING_REGISTERS, SLAVE_POT, 1, SLAVE_POT);
//Packet2: slave 1, write, to slave register MASTER_POT, length 1, put into slave register MASTER_POT
modbus_construct(&packets[PACKET2], 1, PRESET_MULTIPLE_REGISTERS, MASTER_POT, 1, MASTER_POT);
// Initialize the Modbus Finite State Machine
modbus_configure(&Serial, baud, SERIAL_8N2, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, master_regs);
modbus_update();
// Read master pot and store in master_regs[MASTER_POT] for writing to slave
potValue = analogRead(potPin);
// Get slave pot value from master_regs[SLAVE_POT] and blink LED based on value
slave_pot = master_regs[SLAVE_POT];
currentMillis = millis();
if (currentMillis - previousMillis >= slave_pot){
if(digitalRead(ledPin) == HIGH){
digitalWrite(ledPin,HIGH);
Slave:
#include <SimpleModbusSlave.h>
#define baud 9600
#define slaveid 1
enum
MASTER_POT,
SLAVE_POT,
NO_OF_REGS
unsigned int slave_regs[NO_OF_REGS];
unsigned int master_pot;
modbus_configure(&Serial, baud, SERIAL_8N2, slaveid, TxEnablePin, NO_OF_REGS, slave_regs);
// modbus_update_comms(9600, SERIAL_8N2, 1); not necessary
modbus_update();
// Read slave pot and store in slave_regs[SLAVE_POT] for reading by master
slave_regs[SLAVE_POT] = map(potValue, 380, 630, 0, 1000);
// Get master pot value from slave_regs[MASTER_POT] and blink LED based on value
master_pot = slave_regs[MASTER_POT];
if (currentMillis - previousMillis >= master_pot){
